| Home > Help Needed / General Tech Chat > Shopping list | |||||||
194 Posts Member #: 1296 Advanced Member Milford Haven Pembrokeshire |
14th Jan, 2007 at 09:58:53am
I'm currently running an eaton charger with a suck through 45 webber, I'm intrested in converting to a blow through system, could I get some advise on what carb, intercooler and hoses to use and where to purchase them? |
14th Jan, 2007 at 10:33:49am
Carb wise you will need a sealed unit and there are only two real options (although there may be others):
14th Jan, 2007 at 10:35:33am
IC and hosing is a suck it and see matter, whatever fits is the answer there!!
14th Jan, 2007 at 10:36:19am
You type faster than me Rob Every day is a school day ...........
14th Jan, 2007 at 11:16:25am
Thanks for the advise, i've been reading through the links you've posted and it does say that on a twin screw charger (eaton m42) the throttle body must be placed before the charger. I understand that a 'big arse' bypass valve may also work, i'll have another search through those sites to see if theres a company selling parts (throttle body and carb).
14th Jan, 2007 at 11:22:14am
I personally think you'd be better off with a turbo as the set up you describe would probably be quite inefficient.
14th Jan, 2007 at 12:25:40pm
I've been researching this a bit more since the other post.
14th Jan, 2007 at 12:59:53pm
Do you think there is any potential in using twin throttle cables, one connected to the carb and the other connected to a throttle body mounted on the inlet of the charger |
14th Jan, 2007 at 01:54:44pm
On 14th of Jan, 2007 at 12:59pm mini23 said:
Do you think there is any potential in using twin throttle cables, one connected to the carb and the other connected to a throttle body mounted on the inlet of the charger No, because you need the blower to operate at atmospheric pressure at the inlet and outlet when the throttle is shut. The throttle on the inlet would reduce the pressure through the blower, thereby reducing the mass flow of air and the heat transfer. I'm probably going to use a bypass made from a throttle body between the inlet and outlet of the blower and actuated by an actuator working on manifold vacuum, so when there is manifold vacuum, the bypass will be open. Edited by Paul S on 14th Jan, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
14th Jan, 2007 at 02:25:43pm
On a suck through system dose'nt the throttle closing reduce the flow of air into the charger |
14th Jan, 2007 at 02:52:56pm
On 14th of Jan, 2007 at 02:25pm mini23 said:
On a suck through system dose'nt the throttle closing reduce the flow of air into the charger Yes. Did you find that your blower got hot whilst crusiing? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
14th Jan, 2007 at 02:58:00pm
Its not really a cruiser and with twin chargers would be even less so.
14th Jan, 2007 at 05:00:13pm
How about fitting an intercooler to your suck through setup?
14th Jan, 2007 at 06:59:29pm
On 14th of Jan, 2007 at 05:00pm Axel said:
How about fitting an intercooler to your suck through setup? You could build a bomb. Personally I would advise against an IC on a suck through set up (unless you're using fuel injection with the injectors on the inlet manifold) as you risk the air and fuel separating and the nice light air will flow through into the engine and the heavier full will drop to the bottom of the IC. Isambard Kingdom Brunel said:
15th Jan, 2007 at 08:04:27am
To keep the charger(s) cooler I was considering fitting water injection at the inlet. |
