| Home > Technical Chat > K1100 & webbers | |||||||
169 Posts Member #: 409 Advanced Member Bristol |
1st Feb, 2007 at 05:27:21pm
Chaps,
Hannibal: There are two ways we can do this: the easy way and the hard way. In a few minutes my friends and I are going to come down on you like your worst nightmare. You're gonna wish the Earth had opened up and swallowed you whole.
1st Feb, 2007 at 05:59:34pm
If you read that article, it tells you that the port spacing is very close to that of the 32 webbers. so unless the 40's or 45's are the same spacing, then i doubt they will fit. I also doubt the webbers will fit under a round nose bonnet without modification to the body work.
1st Feb, 2007 at 07:08:44pm
I was gunna use a set of R1 carbs, i actually bought a set and fitted them to my K1100 head, but with they actually protruded a supprising way forward! I think partly due to the rubber/silicone 'manifold' hoses that are required. They also needed some tweekeing with regaurd to the sliding choke and throttle linkage. Damn cheap mind you, circa 20 quid on ebay!
1425 Posts Member #: 690 Post Whore Norfolk |
1st Feb, 2007 at 07:41:08pm
indeed weber spacing would mean you'd have to move the carbs forward a little to get an intake maifold in there - then you'll need a nose job on the bonnet like the mini in one of the mags recently (8 porter) - I'd have thought bike carbs would be less of an issue - no including sorting the linkage - Antman is going this route - I'm sure he'll be along soon
If Carling made Mini engines
1st Feb, 2007 at 08:41:49pm
I know that bloke with the 8port John, sorted car but looks like, well, somthing from the league of gentlemen lol! Antman - share the wealth old chap!
1st Feb, 2007 at 08:51:20pm
Yes Amals are old tech and very expensive! - current bike carbs aremuch more like it!
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
1st Feb, 2007 at 08:53:05pm
I'm here!! Yeah i am going to try and get mine running on a set of Carbs have a set of Mikunis off an R1. I foudn that the carbs fit the original inlet stubs off the k1100 with a piece of reducer silicon hose (45-38mm iirc). The biggest thing i have yet to find out is whether these carbs are still gravity fed from the tank or can wind the fuel pressure up a bit. The only thing i have heard that can be a problem for these carbs is the angle they sit at. I haven't managed to get close enough to any r1s to see!!
2nd Feb, 2007 at 11:35:28am
40/45 carbs have wider bore spacing than smaller side draught versions. Having had Amals in a 8-port head I would choose ANY other carb. They run great but are not that easy to set up and cold start by flloding the carbs under the bonnet is not that convenient. |
3rd Feb, 2007 at 06:32:57pm
3rd Feb, 2007 at 06:41:12pm
A couple of leads would need swapping I think, most notably the voltage stabaliser as I'm sure it's polarity sensitive (isn't it????)
3rd Feb, 2007 at 06:53:31pm
