| Home > Help Needed / General Tech Chat > first time on megajolt | |||||||
1st Feb, 2007 at 11:50:17pm
Hi all, is there a safe advance to set the megajolt map to across the range when starting up for the first time?
Edited by MarkGTT on 1st Feb, 2007. |
274 Posts Member #: 1174 Senior Member Sunny Southern California, USA |
2nd Feb, 2007 at 02:14:24am
I believe the edis runs at 10 degrees before you connect the magajolt box itself. For the first start, I would run it without the box attached. 61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
2nd Feb, 2007 at 06:31:27am
For a turbo engine, set it to 24 deg everywhere. It'll start and run, and run boost (lots of boost in fact) with no problems. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd Feb, 2007 at 09:04:56am
thanks, fingers crossed for the first start up then. |
2nd Feb, 2007 at 12:59:47pm
You could also try the base map alex gave me to run my car in (no boost) http://www.turbominis.co.uk/forums/index.php?p=vt&tid=130898 |
