Home > Help Needed / General Tech Chat > TDC on pulley / trigger wheel position for MJ
MarkGTT
Member #: 1194
Shropshire.
Hi, im fitting a trigger wheel today, and just wanted to check something..
in relation to the timing marks on the timing chain cover where should the missing tooth on the trigger wheel be? assuming that piston 1 is at TDC?
or taking a reference from the pulley where should the missing tooth be? e.g. is it 9:00 o’clock?
cheers. Mark
Brocky
Member #: 224
Katy TEXAS
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=7423
I think its usually 90 degrees before TDC. as per the above link
Even if it is not you can offset the figure in the map etc
Cheers Brocky *smiley*
Edited by Brocky on 2nd Feb, 2007.
MarkGTT
Member #: 1194
Shropshire.
Think i just read on another post that its 90 degrees from the sensor..
oh well i will have a play and see what happens!
Brocky
Member #: 224
Katy TEXAS
Yeh, just read the one I linked and Toms putting it at TDC and then the sensor bracket he does positions the sensor 90 degs before this ie at the front of the engine. *smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Its 90 degrees for a 4 cylinder EDIS
alex
AlexF
MarkGTT
Member #: 1194
Shropshire.
alex, is that the missing tooth at 90 from the sensor?
cheers.
Nick
Member #: 154
Midlands
easiest way to explain it is to put the engine at TDC, the missing tooth at 12 and the sensor at 9...pretty sure thats how mine is, using toms sensor bracket and a pulley machined the same.
MarkGTT
Member #: 1194
Shropshire.
cheers, that clears it up.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
AS bud said...
Its so the MJ sees that tdc on cylinder one is on it way!
It then has 90 degrees of engine rotation to decide what to do and then actually do it! Hence you can run a maxiumum of 50 degrees advance - it needs 40 degrees to make its mind up.
ALex
AlexF
