| Home > Help Needed / General Tech Chat > Cutting into the front panel, under front bumper | |||||||
2nd Feb, 2007 at 06:07:26pm
im wanting to fit my 2wd cosworth intercooler to my mini and i want to fit it under the front bumper where the front numberplate sits. I want to mount it there, with two boost pipes running upwards through the front panel (hidden). Is it ok to cut metal out of this part of the front panel though?
2nd Feb, 2007 at 06:39:34pm
I cant see a problem with this as long as you fit all solid front subframe mounts, I dont mean polyflex bushes though.
I seriously doubt it! |
2nd Feb, 2007 at 07:40:02pm
is the front subframe front crossmember not right behind the numberplate/valance feebs?
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
2nd Feb, 2007 at 07:46:23pm
i'm going to be cutting the metal between the front panal mountings away, i have solid mounts, its just a flappy piece of tin like the rear valance, only inboard of the mounting points though, SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
3rd Feb, 2007 at 06:12:35pm
3rd Feb, 2007 at 06:33:02pm
Good call there Bat, would probably cut the opening with the largest holesaw I could get in and then cut between them to get a nice smooth arc at each end.
203 Posts Member #: 479 Senior Member |
4th Feb, 2007 at 09:06:35am
Be careful as that location would leave it vulnerable to stones and other road debris. |
4th Feb, 2007 at 08:07:23pm
Feebs as your running jolt and a side rad there must be enough room behind the grill? Use a remote oil filter housing and that could free up a bit more space!
7th Feb, 2007 at 12:47:59am
Ive had a really good look though and there is room to run two boost pipes up between in front of the subframe and behind the front panel without cutting the subframe.
7th Feb, 2007 at 01:06:20am
Right ive just done a quick mock up in photoshop it only took 10 mins, this is what it will look like...
7th Feb, 2007 at 07:19:24am
Looks good febbs however I would be worried about damaging it and also how much you are reducing efficiency by covering up so much of the frontal area.
7th Feb, 2007 at 11:47:54am
i wouldnt be overally happy with that location, plus you're covering a good chunk to start with the letters.
7th Feb, 2007 at 12:22:33pm
looks wise i think its spot on! i dont think you'd have much greaf with speedbumps or it being hit by anything much, f it works as well or aslong as you are gaining by fitting it, i'd go for it SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
7th Feb, 2007 at 01:13:19pm
Edited by Bat on 7th Feb, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
7th Feb, 2007 at 01:46:51pm
cool bat Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
7th Feb, 2007 at 09:55:40pm
personally i woudnt do this idea feebs, its good but where are you gonna put your number plate when/if pc plod stops you and insists you ned a proper one? and i defo wouldnt be cutting any holes in the shell.
7th Feb, 2007 at 10:26:28pm
get an rs turbo intercooler and be done
7th Feb, 2007 at 10:51:19pm
As Carl says plod may get upset. If they do you could always hang the number plate infront of the grill for long enough to get the producer ticked off but that might be a real pain if they start to pull you daily (trust me, I know!)
8th Feb, 2007 at 06:27:52am
TD5 is the way to go for a behind the grill, efficient intercooler i reckon if you have megajolt. |
5th Mar, 2007 at 11:15:55pm
Not gonna cut mine now, got talked out of it by too many people :)
6th Mar, 2007 at 10:50:20am
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
6th Mar, 2007 at 12:17:54pm
TJ: roger, scirocco turbo? Was it an 8v with a turbo kit or something else?
6th Mar, 2007 at 12:20:09pm
Don't do it ....... will end in tears!!!! Every day is a school day ...........
well ill get clear pictures and document it on here :)
