Home > Help Needed / General Tech Chat > quicky!!! rear subby bushes?
clubminiflip
Member #: 54
nr coventry
can i change the rear subby trunion bushes without removing the subby? cheers chaps, i know i can do the rears trunions but what about the ones that nxt to the heelboard
Never done it (on the car), but I would think it would be possible. You would have to remove the radius arms to give access to the bolt that hold the bushes in though!
TBH It could take longer, than removing it?
This bolt is a bitch to get to with the subby off (especially if its corroded!) *wink*
Edited by matty on 4th Feb, 2007.
As they're usually siezed in you'll need to turn the bolt to free it. That'll be difficult with it being right next to the heel board.
clubminiflip
Member #: 54
nr coventry
its a subby off job really then! its one of the jobs that may habe to wait then, i just thought someone may know a cheeky method of changing them without taking the subby off
c2_mad
Member #: 4215
hi all...
im in the proces of restoring my mini, so replacing everything i can... i bought a complete kit of poly bushes for front and rear subframe.(from what i read, seems like it was not the best option) any, how many bushes does the rear subframe need, and where do they go? and what do they look like? is it 6 for the back?
any help greatly apreciated.
cheers
cheers
t3gav
Member #: 229
Gavin@minispares.com
kent
Post 76 cars had 6 bushes, pre 76 had 8.
On 6th May, 2009 c2_mad said:
hi all...
cheers
cheers
What's not the best option? buying the whole kit, or using polly bushes?
Jay#2
Member #: 648
Northern Ireland (ex AUS)
My front sub is solid mount and I tend to get the seam sealer on the wing/scuttle joints cracking a lot. Is there a corelation?
On 7th Nov, 2008 Nic said:
naeJ
m
c2_mad
Member #: 4215
poly bushes mate, seems like a lot of people dont like them.
Anton
Member #: 764
Staffordshire
Are your teardrops solid too, as this might cause the cracking.
