Home > Help Needed / General Tech Chat > Edis VR Sensors
Are theyre different types?
Mine seems too long?
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I think that set up is intended for the Cossie sensor ...
do cosworths run edis?
RogerM
Member #: 1217
No, don't think so but they do run a crank sensor and I am sure it lists on the web page that is the one you need for that set up.
Pobably other many cars run the same sensor though not sure which ones.
MarkGTT
Member #: 1194
Shropshire.
yeah you need a magnetti marelli sensor off a cossie.
I have the same bracket and wheel, i asked the same question, search for VR Sensors. *wink*
i can PM you some specs of the sensor if you want.
let me know.
Edited by MarkGTT on 10th Feb, 2007.
I remember this all now, gonna space mine out like Nic did.
Ben H
Member #: 184
Melton Mowbray, Pie Country
That sensor you have is a off a car that has the sensor fitted to pick up off the fly wheel. It will have come off a fiesta, escort or mundano. The other, shorter type, is from a serria or granada. They both work the same, but I do prefer the shorter type.
http://www.twin-turbo.co.uk
themaninthesuitcase
Member #: 1124
Surrey
So does the shorter one (type that the KAD and SC mounts are designed for) work with the MegaJolt system?
Ben H
Member #: 184
yep, all the sensors are the same from fords of that era. Just different sizes tosuit different engines.
Anton
Member #: 764
Staffordshire
which toothed wheel and braket is that one?
Specialist components
The one in pics above is an SC one, almost too nice to go on a mini like mine!
Have to take it all off again though, tonight I noticed the oil slinger plate hiding on the sump guard....groan...
Oopsie
Could have been worse, you could have found it on the garage floor when you got back from road testing it!
