Home > Help Needed / General Tech Chat > rear ARB, where are the usually attaced to?
clubminiflip
Member #: 54
nr coventry
rear ARB, where are the usually attaced to? i have a few spare at home & i cant find pics of wherethey attach for me to get an idea how to fabricate some mountings, the arb bush part is no props but where the ends fit it what i'm after, cheers chaps
if you could put pics up that would help alot
Brocky
Member #: 224
Katy TEXAS
This is jimsters I think ?
Edited by Brocky on 19th Feb, 2007.
jims is ultra tech
i believe they normally go to the rear crossmember of the subframe
I think he's after where it fits on the hub/radius arm.
I haven't got a photo, but mine has a bracket that uses two of the bolts holding the backplate to the radius arm.
Brocky
Member #: 224
Katy TEXAS
I should read things properly...
I haven't got a pic either
mine is different to most, disk brakes make it more of a pain in the arse.
Not sure if these are going to help you.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
The sracer one attaches as seen in the link but I think they are a bit different fron the normal too. http://www.sracer.com/catalog/catalog.htm
Edited by Jay#2 on 19th Feb, 2007.
On 7th Nov, 2008 Nic said:
naeJ
m
clubminiflip
Member #: 54
nr coventry
a ha! i think i've come up with a cheapo-non adjustible ARB to bolt on my car, just need some drop-links & to make a bracket! update to come chaps!
