Home > General Chat > what the hell is this??
Whats with the turbo?
http://cgi.ebay.co.uk/AUSTIM-MG-METRO-TURB...1QQcmdZViewItem
so that'll be in need of a rebuild then,lol.
carl
chinlesswonder
Member #: 1192
In the garage......again!!
not a standard metro one that.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
2 exhaust ports only on the manifold??
At first i thought it was similair to janspeed setup, but where does the exaust go?
I wonder if this is a TT or janspeed single turbo setup for the ford 2.8V6 cologne motor?
These mounted a turbo on one side of the engine (on one vee), and a pipe from round the other side if the engine lead into the manifold.
The Turbine housing looks sized for a 3-litre engine...
Alex1340
Member #: 111
Loughborough
definatly looks like a ford style exhuast ports BUT NO WAY is that going to fit a Mini engine. mite do 2 out of 4 ports on a pinto engine....
Alex1340
Member #: 111
Loughborough
hold up, a metro never had that clutch assembley..... must have been changed...ermmm somthing fishy with that
Damn - I'm good!!!!!
so who's gonna tell him he's a dick head,
Block is a later one - so 'could' be a turbo block; but you're right about the clutch for sure... Pistons certainly 'look' large dished...
I can't argue with that.
I guess he knows it won't fit which is why he is selling it. Probably because he bout it off a lying tosser too.
Alex1340
Member #: 111
Loughborough
i've told him and asked for pics of it fitted. He says "hi alex, clutch system has been converted back to mini clutch being to give it more umpth, was told when i brought it that the metro clutch was crap!! as for the turbo unit i was told that it is a metro turbo and has been modified. thanks
Looks like a big miss mash of bits too me.Lol
clubminiflip
Member #: 54
nr coventry
is'nt it bad when ppl get duped in that way!
it comes down to your own research too though for sure!
but on the flip side, if you know it dont fit the mini/metro it should'nt be sold again as that too piss someone else off
arrrh-well! egay is the best!
Alex1340
Member #: 111
Loughborough
I sent him a second message, and he said he was taking it off ebay..... but he hasn't so far. pointed out his manifold has 2 ports and the mini head has 3.
hehe what a tit!
Went for £200!
Dave .. You're spot on, I've got one of those manifolds from when I used to run a 2.8 turbo Capri. I think that's the Capri turbo too, as it's got the extra bend on the compressor outlet.
AL
Member #: 1347
Croydon (South London)
Hes relisted the turbo
http://cgi.ebay.co.uk/Ford-Turbo-Unit_W0QQ...1QQcmdZViewItem
and from the looks of it correctly too *wink*
