Home > Help Needed / General Tech Chat > Turbo airfilter
Mark1275GT
Member #: 886
London.
Just got a Turbo air pipe. what i need now is the airfilter. what one would i need that will fit it.. thanks alot :)
adam1330
Member #: 238
essex
i got a green air filter from avonbar.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Funny this should pop up. I've spend a bit of this afternoon looking at airfilter housings that I could adapt (remember, daily driver so don't want to be listerning to a cone filter .... also I need something to plumb the re-circ DV into!!
So far I'm not doing very well. Tried housings from Rover 200, Metro's several Citroens, a couple of Pugs and loads of other stuff too.
I'm trying to get it under the wing if I can so it's out of the way.
I have just bought a Mety Turbo housing of the bay so maybe that is the solution.
I know you guys aren't as bothered as I am about keeping it all quiet but it's worth considering how annoying induction noise can be on a motorway journey!
JT
Member #: 637
Hertfordshire
im sure someone told me a old escort filter box is what the era mini used? not sure how true that is.
if your not botherd about noise (like me) then would using a pair of tights or similar be any good?
or would it soon cause proplems?
cheers
josh
Edited by JT on 3rd Mar, 2007.
My build thread..
Mark1275GT
Member #: 886
London.
so what sort of filter would i need.. oiled filter ? or what.. thanks...
The hose comes of the turbo, just need the right filter to go onto it.. thanks
I used an ERA airbox on mine.....
Alas, parts like that were easily obtained through the Rover/Unipart dealer back then.
It uses an XR3i style filter ( I used a K&N. )
Silent induction.
Ignore the poor condition and the fact its lying open a bit....
pass side front wing.
Only downside, is the fact there will always be hot air in that region. Although I did duct it to the front behind the grill where the air vent duct used to be.
Outlet to turbo is via a hole drilled in the inner wing, beside the wiper motor.
Who knows, if you had the part number, some might still exist in the dealer network ??
Maybe someone with some aluminium fab skills, could make one ?
Mark1275GT
Member #: 886
London.
you guys have lost me now lol.
I think this is what im looking for.. lol
http://www.minispares.com/Product.aspx?pid=34115
JT
Member #: 637
Hertfordshire
or theres a green one iv seen fitted to turbo minis.
think avonbar sell them?
My build thread..
MarkGTT
Member #: 1194
Shropshire.
Hi, i have the K&N filter as shown in the link, cant remember where i got it from tho.
Mark.
Mark1275GT
Member #: 886
London.
Mark is it a oiled type air filter?
Thanks alot mate.. nice car :)
All K&N's are oiled... Infact just about every aftermarket filter is.
Mark1275GT
Member #: 886
London.
ok cool, didnt know that.. thanks for the reply :)
No problem, always use the correct stuff to wash and oil it *wink*
Edited by Bat on 3rd Mar, 2007.
clubminiflip
Member #: 54
nr coventry
a pair of my grannys tights are a good airfilter on a bit of old pipe hoover pipe *tongue*
if you cant get thse then i've had a 'green' airfilter in the past & it was very good quality
JT
Member #: 637
Hertfordshire
you will how ever get more power with grannys old tights though lol!
My build thread..
Grannys tights wrapped around the compressor wheel, yuk. I don't fancy having to get them out!
RogerM
Member #: 1217
Each to their own ...... I used to commute in my NA 1380 with a K&N straight onto the back of the carb in the usual fashion ..... 200 miles a day soon became too much and I had to do something about it. Put a K&N element in an RSP cooper airbox (inlet side ducted to the grill which improved matters a little but ultimately there was only one actual solution at that time.
Park the Mini up and forget about it for 2 years!!!!!
As I say, choice is yours....
Maybe that can be my first big alu tig project....fab an ERA airbox !!!
MarkGTT
Member #: 1194
Shropshire.
as bat said mate, glad you like the car.
the green taperd one from avonbar does the tick
small and flows up to 225 bhp with no restriction
their postage and packaging is rather over the top though!
