| Home > Help Needed / General Tech Chat > Changing starter solenoids. Help Needed please. | |||||||
314 Posts Member #: 1311 Senior Member Yeovil, Somerset |
13th Mar, 2007 at 10:16:22pm
A friend is currently wireing his turbo engine into his mini and has changed the cluth to pre verto so he is also changing the wireing and starter solenoid to the type on the inner wing to match.
14th Mar, 2007 at 09:13:00am
After a bit of head scratching ive decided that the yellow/black wire that supplys the coil should not be connected to the starter solenoid (this would make it permenant live), instead i think it should be connected to the fusebox ignition switched live instead.
14th Mar, 2007 at 01:30:34pm
Give me a few hours and ill post a pic (dont have them to hand at work). "Turbo's make torque, and torque makes fun"
14th Mar, 2007 at 06:37:24pm
14th Mar, 2007 at 06:45:17pm
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
14th Mar, 2007 at 11:12:37pm
"A friend is currently wireing his turbo engine into his mini and has changed the cluth to pre verto so he is also changing the wireing and starter solenoid to the type on the inner wing to match" stupid question, but have to ask, is the starter the correct type for the ring gear on the flywheel? Made this mistake before myself.
14th Mar, 2007 at 11:18:52pm
15th Mar, 2007 at 07:43:35am
Cheers for the pics joeybaby83 :)
Edited by Minimad69 on 15th Mar, 2007.
![]() 136 Posts Member #: 5193 Advanced Member Dunstable |
17th Aug, 2010 at 09:04:18pm
dont suppose you could reup the pic ? |
