Home > General Chat > Can anyone here do crank work?
As none of my local machine shops can to balancing & grinding in house and have to send cranks off to be worked, I was wandering is anyone here has the ability. If I've got to send it off to be done I'd rather send the crank to someone on this site than a random company.
I've worked with cranks, do I qualify?
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Rob,
I use S & G Engineering in Gloucester. They don't do the balancing in house but their crank grinding is spot on and the cost for balancing is reasonable.
When I get my mill set back up I'll be able to wedge, bald etc. etc. the cranks for you.
Do you need a hand to get the mill set up?
RogerM
Member #: 1217
No mate, I need a hand to get the car built ..... then I will set up the mill..... *wink*
