Home > Help Needed / General Tech Chat > Fuel Starvation? Help chaps :(
Metro Turbo
Member #: 437
Sunny Blackpool
Hi guys,
Not a very happy chappy, took the turbo out for a blast last night (first time since the recent RR setup), and gave its first session of hard driving. However i've come across a very annoying problem.
I can acclerate hard in 2nd gear, upto 6k....change into 3rd and continue the full acceleration, then at about 4500 revs the engine just dies suddenly. It doesn't cut out, it just gives pop from the exhaust and completely stops accleration.
Now, it must be fuel starvation that is causing this, but surely this would hacve shown up on the roling road last week?
Is my pump not keeping the float chamber level up?
Tim
89' Metro Turbo
157 BHP , 170 lb ft @ 15psi .... So far....
Mikeanics Rolling Road
WINNER OF RETRO CARS SHOW BEST 80's MODIFIED CAR
I had a similar experience, an it was the fuelpump not pumping enough fuel per minute.
it needs to pump at least 1 litre per minute
Metro Turbo
Member #: 437
Sunny Blackpool
How did you cure the problem?
89' Metro Turbo
Me too, new fuel pump sorted it.
Metro Turbo
Member #: 437
Sunny Blackpool
Hmm...the pump is relatively new, only replaced it about 5000 miles ago.
However, it could be faulty I suppose?
Or I may have a slightly clogged fuel line, restrciting flow?
89' Metro Turbo
JT
Member #: 637
Hertfordshire
wouldnt it effect it in all gears if it was fuel starvation??
My build thread..
slater
Member #: 1291
Suffolk / Birmingham
What sized lines have you got?
Metro Turbo
Member #: 437
Sunny Blackpool
My thoughts were that if the fuel pump wasn't quite keeping up with the rate at which the fuel was being drawn from the float chamber, then eventually under prelonged acceleration there would come a point when the float chamber is empty?
Standard turbo lines, they've not been touched since the car was new 18 years ago.
89' Metro Turbo
miniminor63
Member #: 672
The oversills police
Oslo, Norway
Could it be that the carb is full of crap? maybe take a look to see if anything is blocking fuel flow inside it?
Metro Turbo
Member #: 437
Sunny Blackpool
Just stripped and rebuilt the carb last weekend, so its defo not that.
And I doubt the fuel lines are blocked as i could give the car hell with 130BHP and it fuelled fine...
Its with 160BHP that i'm now struggling for fuel, so i suspect the pump isn't keeping up.
89' Metro Turbo
gutted
Member #: 645
Derby
Tim,
If it was fuel starvation, I'd guess (?) that the float chamber would empty out well before you got to 6k from in 2nd. Could it be ignition timing that's giving you grief? I always say this in similar situations only because I had very similar experiences which eventually turned out to be the vacuum advance unit on the dizzy being slightly loose. Not saying yours is necessarily loose, just wondering if it's an electrics thing rather than fuelling?
Dan.
Edited by gutted on 17th Mar, 2007.
Metro turbo owner
It might be that 130 Bananas is about the limit for the standard pump, after all it's well above standard!
Metro Turbo
Member #: 437
Sunny Blackpool
On 17th of Mar, 2007 at 06:51pm gutted said:
Tim,
Dan.
I'd like to think its not timing related, as its just been rolling roaded and set up last monday!
I'm thinking theres a small difference between the pump supply rate, and the rate at which the fuel is leaving the float chamber. Hence it takes 15/20secs of constant full acceleration before the float becomes empty?
89' Metro Turbo
Dangerous
Member #: 417
Std metro supply pipe is only 1/4" o/d,a 1/4" i/d pipe will only supply fuel for 250 HP
metroturbo
Member #: 989
North Yorkshire
Do you still have the ballast resistor in the supply circuit for the pump? (it is the white thing under the battery.) If so, it might be worth linking it out to get the pump up to full flow rate and see if that helps.
Metro Turbo
Member #: 437
Sunny Blackpool
Its still got the ballast resistor in place at the moment, is it safe to link it out?
Are there any negative side effects to be careful of if I link it out?
89' Metro Turbo
That's a good point. Only Rover would reduce the power to a fuel pump!
Metro Turbo
Member #: 437
Sunny Blackpool
So are we saying the fuel lines need replacing with 1/4" i/d piping?
89' Metro Turbo
Dangerous
Member #: 417
Well a 1/4" i/d pipe will have a cross section of pie x 3 squared =28 sqare mm
so if the i/d of the metro pipe is 4 mm then that will be 12 square mm
if 28(1/4 i/d) is good for 250 bhp, then 12(4mm i/d) will only do about 120 bhp
Easiest way would be plumb the return pipe for the flow and put a bigger return pipe on.
I've got no idea why the ballast resistor is there in the first place? It's a 12v pump so I don't understand why they don't supply it with 12v in the first place?
Metro Turbo
Member #: 437
Sunny Blackpool
I see....So looks like I have to get busy with my fuel lines :(
Thats going to be a b*stard of a job to do.
How would I go about connecting up the larger bore lines to the fuel pump etc?
89' Metro Turbo
I'd bypass the ballast resistor first, that's the easier job of the two *wink*
As regards the fuelline - I think you'll be fine. You just need a full 12V (or a tickle more) voltage to the pump.
Metro Turbo
Member #: 437
Sunny Blackpool
PROBLEM SORTED!!
Linked out the ballast resistor and taken it to an airfield for private testing (cough cough)
Tested it upto 120mph before it looked like the bonnet was going to fly off!
Chuffed to bits, no signs of fuel starvation now!
Thanks for info guys, thats made my weekend now thats sorted :)
Tim
89' Metro Turbo
had the same problem and know many peeps who has been there
the HIF range of carbs struggle with fuel supply delivery been out stripped in the float bowl at around these power figures
the answer here is to remove the carb needle valve (the fuel jet)
and drill this out carefull to 2.9mm no bigger or smaller 2.9mm
then seat the valve in using very fine lapping past, taking any! micro scratches out of the seat
Mr Avonbar can..... supply you with a modded one for around £11 BUT..... *frown*
their postage fees leave somewhat to be disired *frown*
my moneys on this if all else checks out *wink*
edit: The fuel pump from the mg metros are rated at fuel flow rates at a shade ove 500BHP
in good order
Edited by BENROSS on 18th Mar, 2007.
