| Home > Help Needed / General Tech Chat > Urgent Advise Needed | |||||||
332 Posts Member #: 483 Senior Member Merthyr Tydfil |
19th Mar, 2007 at 05:36:45pm
Help! I took my mini to work today and when I got home and tryed to reverse my car in the garage and everytime I put it into reverse it cuts out!
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
19th Mar, 2007 at 05:48:08pm
do you have reversing lights, maybe a short somewhere, or does it cut out in all gears, bit more info needed i think "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
19th Mar, 2007 at 06:08:50pm
I think it could be electrical as well.
19th Mar, 2007 at 06:44:59pm
Can't you just push it into your garage, at least that way its out of harms way(Mr Plod) and work on it there. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
19th Mar, 2007 at 06:50:24pm
Check all the earth connections on your car, clean them and I am certain your problems will dissapear.
19th Mar, 2007 at 07:16:22pm
Deffo electrical. Get the above done laddy! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
19th Mar, 2007 at 07:24:08pm
19th Mar, 2007 at 08:00:58pm
Hi I checked and the reverse lights were not working so i checked over the wire and where it comes through underneath the car was bare wire touching I replaced it. I though it was going to be alot worse than that. phheeww! cheers guys i think ill post some pics of my car |
21st Mar, 2007 at 08:13:51am
Its def electrical when the car is running if i put on the inicators, rear heated screen or put it in reverse the car cuts out! is this just down to bare wire on the body draining all the power do you think? |
21st Mar, 2007 at 12:51:40pm
I've not got a wiring diagram to hand (not that I ever wire one up in the original way) but are they all on the same connection at the fuse box (live feed or fused side)????? Might be a problem there.
22nd Mar, 2007 at 08:26:56am
When I disconnect the reverse switch and put it in reverse the car does not cut out! I took of the heater and checked wether any of the wires near the bulkhead box hand been singed but there all fine!
22nd Mar, 2007 at 12:20:54pm
Try disconnecting the live feeds from the fuse box and instead connecting the fuse box to the main live (big cable, at starter). If it works now then you probably have a problem with the live feed to the fuse box.
22nd Mar, 2007 at 01:04:08pm
ok thanks ill check that tonight and get back. |
