Home > Help Needed / General Tech Chat > -31 Actuator T3
MarkGTT
Member #: 1194
Shropshire.
Hi, sorry if this is all a stupid bunch of questions but...
is the attached actuator suitable for the metro T3? also does anyone know what psi they are set to? or is it adjustable? also what does the -31 mean?
is this type any good?
http://cgi.ebay.co.uk/Black-Collins-31-Act...5QQcmdZViewItem
cheers.
Edited by MarkGTT on 21st Mar, 2007.
AL
Member #: 1347
Croydon (South London)
i think -31 is 15psi but not sure. But im sure you can change the springs in those collins ones. If it fits an rs turbo it should in theory fit a mini t3, only problem might be clearance as those ones are quite big iirc.
go for a 8 psi actuator and bleed the signal off for further boost
maestro 2.0 litre turbo actuators are if iam correct are standard set at 8psi and are alot cheaper than the Bling billet ones
AL
Member #: 1347
Agree with benross, im using a standard rs turbo actuator (if my car ever gets finished) which i think is 8psi and is identical to the standard mini/metro one.
MarkGTT
Member #: 1194
Shropshire.
Ok thanks for the sound advice, i have the standard metro actuator at the moment, and an MBC, just wondered if its work going for an uprated item.
All actuators are adjustable, you shorten the rod for more boost, until the spring isn't strong enough to hold the wastegate shut.
The -31 has a stronger spring than the standard actuators. My -31 runs at 25 psi, not on an A series though!
Using a bleed valve does reduce midrange torque I believe
MarkGTT
Member #: 1194
Shropshire.
so for instance it better to have a 12psi / 15psi actuator if thats what i want to run? rather than bleed it off?
well there are swings and roundabouts to this and many ways to plumb things in as most would agree!
in my book i would go for 8 psi actuator as standard kinda for going shopping etc.... and bleed the signal off to higher figures
for chav bashing *laughing*
place a flow regulator choked down in between the pressure side take off from the turbo to the mbe
you still get the pressure to open the wastgate but..... with NO flow loss
also the benefit of this is you can adjust the mbe in very,.... small increments to increase boost, rather than winding it round and around to gain only a few pounds of boost
on my motor
from the 12 Oclock position to quarterpast its the scale
its 8psi shut, to a compleate blank on the actuator .....eech! at quarterpast *wink*
AL
Member #: 1347
better to have an actuator near what boost you want to run as it will hold boost nicer than say a standard metro one with loads bled off
Dangerous
Member #: 417
-31 is inches of some liquid in a tube
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I agree with Steve .... go for about 8psi as that is sensible for day to day then use a plunger and spring type mbc as they only open when you get to the setting you want rather than constantly trying to bleed off. This means the boost rises better and gives more mid range.
Never been a fan of the constant bleed type devices.
MarkGTT
Member #: 1194
Shropshire.
cheers chaps that clears it up, Steve again very sound advice an 8psi actuator it is. :)
MiniTurboBadBoy
Member #: 483
Merthyr Tydfil
Im running a standard 1275 and I have a metro actuator and a bleed valve to achieve constant 8psi.
If I fit the Maestro 2 litre turbo acuator. It will run 8psi without the bleedvalve and increase torque
If so I think this is a nessasary Upgrade!
Skinns46
Member #: 165
Cambridge
-31 actuators will give 8psi with about a 1mm preload. Trust me i did it last week. I also know they will boost 28psi+. The only problem is the springs are so strong it's difficault to hook them over the wast gate (on a mini). I make the rod adjustable.
cheers
Roland
http://photobucket.com/albums/y139/Skinns46/
