| Home > Beginners Tech > Couple of newbie questions | |||||||
487 Posts Member #: 1495 Senior Member |
26th Mar, 2007 at 08:41:17pm
Just a couple of questions now that ive stripped my engine.
Edited by webba on 26th Mar, 2007. |
26th Mar, 2007 at 08:50:11pm
26th Mar, 2007 at 08:50:25pm
On 26th of Mar, 2007 at 08:41pm webba said:
Just a couple of questions now that ive stripped my engine. Conrods - How do u get the old pistons off the conrods? I've always resorted to taking them to a machine shop and getting them to press the grudgen pins out. On 26th of Mar, 2007 at 08:41pm webba said:
Gallery Plugs - Whats the best way to get gallry plugs out the block without damaging the block itself? Drill a small hole in them, tap it, screw a bolt in and pull it out. On 26th of Mar, 2007 at 08:41pm webba said:
CR - Would a CR of 8.5 on a 1293 be sufficient, I basically dont plan to go over 8psi and want a reliable daily driver. Sounds a bit low. Isambard Kingdom Brunel said:
26th Mar, 2007 at 09:03:04pm
Thanks for the info, im still new to CR Science!
