Home > Help Needed / General Tech Chat > uprated altenator - AC DODD?
pot_dan
Member #: 326
bradford, west yorks
i bought a 65amp, (i think) alternator from Mr. Dodd a year or so ago and it came with an earth cable, i have never had to fit an extra cable to an alternator before..does anyone have any ideas where i need to connect it to? lol i have done a search and cant even find his email adress...
also slightly different, the really small connector on the bottom of the starter solenoid (the bottom most one i think, on the piggyback type) should this actually be connected to anything? i have managed to rewire the whole front end of the car but this bit i cant work out for sure?
thanks. Dan
icklemini
Member #: 745
Northampton
the earth cable would go between the alt body and the body of the car...
the + cable would go between the alt output and the main battery feed on the solenoid.
icklemini
Member #: 745
Northampton
iirc the uprated alts that doddy supplied came with a cable that goes from the large threaded terminal on the alts to the solenoid + (ie: its an upgraded output cable... not an earth cable...)
That makes more sense to me ( the positive cable) I think I've read that somewhere too.
pot_dan
Member #: 326
righty! i have seen a couple of threads on it that could be taken as terminals, so i wil have a closer look to see wich one i think its most likley to be... expect a pic of it soon, lol
thank you!
Dan
themaninthesuitcase
Member #: 1124
Surrey
Why don't you ask AC?
http://www.mlmotorsport.com/index.php?opti...m_smf&Itemid=26
