Home > Help Needed / General Tech Chat > Alloy Joiners
Mark1275GT
Member #: 886
London.
If i wanted to make up something like this in the pic for my metro rad which sit's at the front... could i use Alloy Joiners ?
Would it stand the heat from the water.. could someone lighten me up abit more on this pretty please :) or better still, give us some advise on best option.. thanks alot..
P.s, sorry is this has already come up :)
http://allyoucanupload.webshots.com/v/2000966084854313794
yes no worries with alloy
dont go too thin walled as it may crush
Mark1275GT
Member #: 886
London.
would you know what one i should go for then..
These ok on here
http://www.samcosport.com/raceparts.asp
Mark1275GT
Member #: 886
London.
or would Metal Hose Joiners be ok ?
They'll be fine. You may find Merlin Motorsport cheaper. Just measure the pipe stub sticking out of the rad and away you go.
Mark1275GT
Member #: 886
London.
Hi Bat,
Say i have all the hose pipe's at 32mm.
Would it be best to have the Joiner's at The same size, or 1 or 2mm bigger.. Thanks alot
