Home > Help Needed / General Tech Chat > May be a daft question but...
webba
Member #: 1495
Water Heated inlet manifolds.
I thought the whole idea was to get the air cold and dense as possible into the engine, so why heat it?
Secondly do you really need to plumb it in?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I think...and I have a limited knowledge...mainly to heat the fuel for better mixture. Only a guess though. Problably more chemistry to that
On 19th Jan, 2010 wil_h said:
webba
Member #: 1495
Its ok, found the answer on mini infinity. Think ill just leave mine off.
If you use your car in the winter, or have a large intercooler and do long motorway runs you should connect it.
Carb icing isn't nice!
Don't believe what you read on other BB's *wink*
I'd connect mine if I had one :(
Edited by Bat on 4th Apr, 2007.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Do a search mate ... been covered a few times recently on here.
I'd connect it myself .... and always have done.
