Home > Help Needed / General Tech Chat > Standare Mini Switches
Anton
Member #: 764
Staffordshire
Anyone know of a standard mini switch (the later squarer type) that is normally closed?
It dont matter what it attually says on the front tbo.
Only one i can think off is a hazard light switch but i dont have a spare and its also the most expensive switch..
Any ideas?
Anton
Any of them mounted upside down!
Failing that use a 5pin changeover relay ... Connect your whatever to pin 87A *wink*
Anton
Member #: 764
Staffordshire
doh i'm having a dopey moment!... of course turn it round would be the most obvious answer... cheers
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Doh!!!!
I don't know where I got that flash of inspiration. I'll be f..cked for good ideas for weeks now :(
I had a dodgy fog lamp switch at the last MOT, I pulled it apart cleaned the contacts up and got really confused for a couple of minutes when i put it back and it worked the wrong way round, LOL.
Mini 13 is right. Rather than mount it upside down, take the back off and reassemble it upsided down; that way it won't look silly on the dashboard.
