Home > Technical Chat > Picture of ND Japanese Alternator
dn89mini
Member #: 1506
Cheshire
Does anyone have a picture of the small ND alternators installed? I searched and found one of Fastcarl's rear engine, awesome but I am looking specificaly for how people have adapted or made the bottom mounting bracket to fit in a "normal" car.
At the moment the only way I can seem to get mine to fit is by having it at such an angle that the mounting lug sticks out almost as far as the original one, the reason for changing is to get a bit of space in there for a front mounted rad.
I would appreciate any pictures you may have to give me some ideas on how you guys solved this problem.
Many thanks
Check out the (slow) progress at.......
http://www.turbominis.co.uk/dn89mini
I had a look at fitting one on mine, have you tried turning the adjusting bracket round so the slot is on the alternator.
You may need to make a new adjusting bracket.
It was a while ago, hope that helps?
i just filed the face that meets the watre pump down until the pulleys lined up.
this bit:
dn89mini
Member #: 1506
Cheshire
Thanks! I appreciate your help
Alex1340
Member #: 111
Loughborough
Nice to see a Morspeed engine. Which car is that alternator off? any problems with the wiring?
i got the alternator off a guy on here, not sure whats its off, but would love to find out so I can gte a plug for it.
Yes, it would be even nicer to see a head on that engine.....
dn89mini
Member #: 1506
Cheshire
I got mine here, he has the connectors too
http://cgi.ebay.co.uk/Denso-Performance-Li...1QQcmdZViewItem
