| Home > General Chat > Carb on a N/a | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
6th Apr, 2007 at 10:55:54am
Hi guys, I fancy a change, my 1380 mini doesn't get used as a daily drive any more so i can go for a bigger carb set up in the hunt for alittle more power. my choice seems to be Webber/dellorto or twin SU i fancy twin HIF38 and build my own linkage they will fit on to a HS4/6 twin manifold if i put in a extra few studs. I don't want to cut in to the shell and i seem to remmber afew years back there is and manifold for mounting the webbers with out cutting but it does loss some power from it, any one remmber this and know where i can get one? Comes down to twin SU or webber. What you think? |
2645 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
6th Apr, 2007 at 11:26:19am
Su's! but I have had no experience with webba carbs, I think there is a bit more to them then the su fuel needle for mixture, think ther is alsorts like emusion tubes, idle jets etc, but if you can get one thats been set up for a mini I gues its not a problem?
6th Apr, 2007 at 11:30:16am
No point in changing the carb unless the head and cam can handle the extra air flow.
6th Apr, 2007 at 11:39:51am
When I took the Webber off my 1380 to make it nicer as a daily driver I went back to my HIF44 (vizzard type mods admittedly). It is SO MUCH NICER TO DRIVE with the SU on. The webber was fluffy at the bottom end and it wasn't exactly good on fuel.
6th Apr, 2007 at 01:28:53pm
The head and came will take the flow, Morspeed stage 3 head and a kent 286 cam and 1.5.1 roller rockers. The car isn't beening used as a daily drive any more so will be mainly used for the odd trash and country drive. Im worried with the cam and rockers the single HIF44 won't give enough flow to the engine and hold the thing back.
6th Apr, 2007 at 01:41:25pm
the thing with webbers is there much harder to set up than the SU's as like Shane said there more bits on a webber to set up.
My build thread..
6th Apr, 2007 at 04:20:51pm
It is spelt "WEBER" not "WEBBER" or "WEBBA".
6th Apr, 2007 at 04:49:47pm
On 6th of Apr, 2007 at 01:28pm Alex1340 said:
Im worried with the cam and rockers the single HIF44 won't give enough flow to the engine and hold the thing back. I wouldn't worry too much after all the flow well enough for 200BHP+ turbo lumps. Isambard Kingdom Brunel said:
6th Apr, 2007 at 05:37:55pm
and the hassle of constantly setting the floats with webers! On 19th Jan, 2010 wil_h said:
6th Apr, 2007 at 05:43:14pm
6th Apr, 2007 at 06:01:35pm
Ida weber,filter straight up through the bonnet
6th Apr, 2007 at 07:10:36pm
ok, discounted the weber. What about Twins over single? |
6th Apr, 2007 at 07:19:29pm
6th Apr, 2007 at 08:31:14pm
Use the Maniflow 3.5" inlet, you can get it a 45dcoein with no mods to the bulkhead with the ram pipes sticking through the original hole. I used this arrangement and showed 134 bananas on Swiftunes dyno.
I seriously doubt it! |
![]() 100 Posts Member #: 1426 Advanced Member Birstall, Yorkshire |
6th Apr, 2007 at 10:03:08pm
I've got a vizzard modded HIF44 running through a stage 4 longman head with a 274 scatter cam and it fuels fantastic with very little, if any, maintenance required.
6th Apr, 2007 at 11:22:26pm
What does Vizzard do to the carbs keep hearing people mention a vizzard modded carb but i don't know whats changed on them. |
6th Apr, 2007 at 11:48:06pm
7th Apr, 2007 at 10:04:43am
Any one got the pages they could scan in for me to read though?
7th Apr, 2007 at 01:36:57pm
Go buy the book you tight sod.
7th Apr, 2007 at 03:38:08pm
Agreed tom, best book i've bought. And well worth the money!
