| Home > Help Needed / General Tech Chat > wierd problem | |||||||
![]() 1128 Posts Member #: 142 Post Whore Winchester |
10th Apr, 2007 at 12:08:49pm
hi everone,
10th Apr, 2007 at 12:13:25pm
just to add, when i got it home and checked under the bonnet, there was fuel coming from around a bolt on the carb (number 1 on the picture)
1050 Posts Member #: 764 Post Whore Staffordshire |
10th Apr, 2007 at 12:48:48pm
have you done a compression test? |
10th Apr, 2007 at 12:52:59pm
no, not yet, but someone on another forum suggested this as well, so i am off to get a compression tester and see what i can find.
10th Apr, 2007 at 12:54:44pm
out of interest, would you mind posting a pic of your webers tps setup? "Turbo's make torque, and torque makes fun"
![]() 902 Posts Member #: 111 Post Whore Loughborough |
10th Apr, 2007 at 01:01:24pm
Compression wouldn't course a backfire from the carb.... got to be firing at the wrong time. Is the crack sensor been hit but somthing or the sensor wire no longer earthed? try disconetting the HT leads and cranking it over and see how it turns over. |
10th Apr, 2007 at 01:03:29pm
if an inlet isnt closed it might pop "Turbo's make torque, and torque makes fun"
10th Apr, 2007 at 03:00:26pm
If the problem is carb related as maybe indicated by the leak at the brass fitting it might be worth checking the following.
10th Apr, 2007 at 04:30:05pm
hi guys, thanks for all the replies, much apreciated.
10th Apr, 2007 at 05:04:45pm
10th Apr, 2007 at 05:08:11pm
i took the crank sensor off and checked it earlier, it looked fine. |
10th Apr, 2007 at 05:17:51pm
10th Apr, 2007 at 05:22:09pm
i will double check the sensor location and make sure that it hasent moved, i am using the kad trigger wheel so there may be a chance that the trigger wheel has rotated.
10th Apr, 2007 at 06:14:10pm
cheers for the pics, and good luck sorting it!
10th Apr, 2007 at 07:11:16pm
Fixed it!
10th Apr, 2007 at 07:19:59pm
11th Apr, 2007 at 11:27:45am
Right so a really good VR sensor bracket is the key. |
11th Apr, 2007 at 11:45:23am
sounds like the actual problem was the bolt on trigger wheel was the problem, not the VR sensor bracket. |
