| Home > General Chat > high quality h2o???!!!! | |||||||
831 Posts Member #: 908 Post Whore gateshead |
14th Apr, 2007 at 10:56:06pm
alright.
balls to the blower!!!
14th Apr, 2007 at 11:11:25pm
As with most things the answer is yes and no,
15th Apr, 2007 at 07:38:16am
174 Posts Member #: 781 Advanced Member Norway |
15th Apr, 2007 at 11:59:41am
Do both! |
15th Apr, 2007 at 03:53:43pm
hmmm. i can easily find somewhere to plumb in the w i sytem betwee the carb and blower. plus, i might be able to use the megajolt system as the pressure switch too. i would of used an intercooler, exept i really, really dont have any room between the blower and engine!
15th Apr, 2007 at 05:52:24pm
I was up at Vmax a while ago and saw their chargecooler setup, basically its some copper tubes in a plate between the charger and manifold, not very big but apparently enough to take the edge off the temps.
15th Apr, 2007 at 09:55:51pm
yeah thats my problem and i havent got any room between the blower and manifold. it really is all a tight squeeze!
15th Apr, 2007 at 10:58:53pm
Don't know much about it, I don't know any minis that run it, and i know people that have removed kits from cars. Best 1/4 mile 13.2 seconds @116 mph
15th Apr, 2007 at 11:19:52pm
I did run it and still have the injector somewhere in the garage, I felt it was more of a gain to run an intercooler.
Edited by giallofly on 15th Apr, 2007. On 21st Jan, 2011 fastcarl said:
16th Apr, 2007 at 12:48:56am
i dont think i need an intercooler tbh. due to the volume of air being sucked on boost, the air gets so cold it freezes the manifold pipe up. a lot of the v max kits have this too. now i know it isnt good to have this because it means the pipe isnt big enough, but, it also means the air is quickly cooled, before entering the blower, thus dropping the temp. same effect as an intercooler basically, but in effect using a long venturi. or am i talking bollocks??? balls to the blower!!!
16th Apr, 2007 at 07:15:59am
16th Apr, 2007 at 02:00:51pm
hmmm could do. then see if the water cools it by much. hmmmmmmmm the cogs in my head are turning!!!
16th Apr, 2007 at 02:36:42pm
first thing i'd do is stick a IAT gauge in. just a cheap tim water one or something ill give a good indication. On 28th Aug, 2011 Kean said:
16th Apr, 2007 at 03:21:50pm
i will do. right between the blower and charger then see what i get.
16th Apr, 2007 at 05:18:43pm
i run a charge cooler and i was running an intercooler and water injection.
17th Apr, 2007 at 03:51:53pm
i run megajolt not squirt, but there is way to control an output from it so could use that! just need injector and pumps really! balls to the blower!!!
