Home > Beginners Tech > crankcase breather location
chappers
Member #: 1428
Cleveleys
Hi
I'm wondering where to put a breather on the A+ 998 turbo.
I'm using an MPi manifold, so the tappet cover breather fouls the manifold.
Could i weld this breather to the rocker cover? and blank off the tappet cover?
any suggestions
Chris
998 turbo in progress.... DONE..........KNACKERED LOL
You could go for one on the transfer housing, just drill out the big hole, drill and tap to bolt holes. Get a breather from a 1275 job done.
The cans need to be uprightish, so you're going to struggle to get one on the rocker cover.
Scruffy
Member #: 328
Seaford Rise, South Australia
If you are ditching the dizzy use the dizzy hole!
On 5th Sep, 2011 Vegard said:
chappers
Member #: 1428
Cleveleys
yeah both places will be a problem.
I'm keeping the dizzy and i'm doing a flywheel mounted turbo set up. so the breather will get in the way there.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Sounds like breather on the rocker cover and an oil catch tank is your only simple option.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
fuel pump hole?
timing chain?
chop the can off the rocker cover one and run it to a catch tank.
sure feeb's has done the same thing.
then i'd have one from the rocker cover to the catch tank too.
i currently run one on the timing cover and a large on on the rocker cover to a catch tank and it seems to work.
Edited by iain on 15th Apr, 2007.
chappers
Member #: 1428
Cleveleys
ok cool
getting a step closer to understanding turbocharging engines, really appreciate the help you guys give.
Chris
