Home > Help Needed / General Tech Chat > help my mini turbo is smoking badly
stace
Member #: 987
hi. trying to diagnose my minis smoking problem. Doesnt seem to smoke on tick over but give it a few revs and it chuffs out a light blue almost white ish smoke. Also when turbo comes on boost it chucks it out and also does so if you let off after. It recently had new rings and valve stems have been done. Hoping its not the rings again and its turbo. Any advice much appreciated. thanks
Jason G
Member #: 1459
En-suite user
Braintree, Essex
White ish smoke.....try a compression test first before anything....
Maybe head gasket
Edited by Jason G on 15th Apr, 2007.
On 19th Jan, 2010 wil_h said:
stace
Member #: 987
hi did one all seams ok all the same too across all 4
stace
Member #: 987
also did the headgasket on thursday. still smoking help.
Richie
Member #: 628
possibly the oil seals on the turbo ?
Edited by Richie on 15th Apr, 2007.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
sounds turbo related if its on and off boost.
possibly oil pressure related???
Scruffy
Member #: 328
Seaford Rise, South Australia
Maybe head gasket
Cylinder leakage test is the only one that will tell you owt!
On 5th Sep, 2011 Vegard said:
take it from me, the turbos Goosed!
get another one
Richie
Member #: 628
new ones from avonbar are circa 300, or u can hedge ure bets and get a used one, but it is kinda russian roulette seond hand....unless u get one from a trusted user at this fine forum *wink*
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
stace
Member #: 987
Got another turbo in me garage so will change it over on thursday and try that. hope its that dont wanna have to get another rebuild on the engine
*wink*
When you get the current turbo off, take a good look at it to see if you can see where the oil is coming from.
