Home > Help Needed / General Tech Chat > gearbox probs
any ideas why i cant get reverse? was working fine last time i used car, use it today and i can get every gear bar reverse, ive checked the stop nut and the big nut are set correct
Is it crunching or goes in and won'y get drive. Gear leaver won't get there?
wont go in at all
I couldnt get reverse on minebut could today! lol!
mines internal gear linkage though so thought maybe adjustment.
have you got a centre bias fitted? sometimes those foul?
or maybe the roll pin has moved and is catching the casing?
the rod change bit is the easy bit to check to make sure your getting full movement.
also try it without the engine running and just rock it a bit to get it in. if so then its clutch but i doubt it.
Could also be the quick shift if you have one fitted.
Edited by iain on 20th Apr, 2007.
What he said. Check over all the external parts first + cotton reels on the remote.
andeh
Member #: 97
Near Daventry, midlands
best case scenario, its a linkage problem. If all else fails adjusting the selector linkage try using some molegrips to make sure everything is ok internally, as....:
worst case scenario, the internal bush has slipped within reverse gear making selection impossible
turbo hogster
Member #: 178
stowmaket suffolk
wolfie if youcheck every thing and still cant get reverse the i recon the bush has moved inside the gear pushing the gear outwards meaning the the bell lever wont engage.
i have had this happen before on my box, when building i always check the security of the bush, but the have been know to move.
if this is the case the only way is engine out im afraid,
turbo hogster
Member #: 178
stowmaket suffolk
thinking about it it wont be the bush, as the outershaft will stop this, when the bush moves it gets stuck in reverse not the other way round.
sounds like gear lever proplem.
to double check remove lingage from box shaft.
them using a drift slide through roll pin hole and turn all the way clockwise (looking from the back of the engine looking forwards) untill it stops then gently tap with a hammer untill it engages then turn the engine over with wheels in the air and see if the wheel turns backwards or forwards, hopefully backwards.
this should rule out box problem.
my guess is the gear stick end.
i take it the gear leaver pulls up and fully over ok.
also check roll pin hasnt came out some way as this can happen if its an old pin.
dont hessite to ring me neil or pm me.
regards richard
