| Home > Help Needed / General Tech Chat > Help with steering column please | |||||||
![]() 214 Posts Member #: 1574 Senior Member Malta |
21st Apr, 2007 at 07:06:26pm
I fitted a new steering rack (awful job) and then fitted a new column. The problem is I now have 2.5 turns to lock to left and 1.75 turns to lock to right. Anyone give me a clue what I've done wrong? The Hayens manual is 'crap' on this subject.
![]() 1014 Posts Member #: 238 Post Whore essex |
21st Apr, 2007 at 07:18:07pm
the rack needs centralising. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
21st Apr, 2007 at 07:49:18pm
Any chnace you could post an 'idiots guide' on how to centralise the rack? I've never done it before.
21st Apr, 2007 at 08:00:11pm
undo steering columb from rack, then ensure the wheels are pointing straight ahead, provided you have'nt got on track rod end wound all the way in and the other out you should be fine....
21st Apr, 2007 at 08:08:25pm
Thanks.
21st Apr, 2007 at 08:11:42pm
The Haynes manual shows pictures of where the centralising pin should be inserted. Read it carefully, its very easy.
I seriously doubt it! |
21st Apr, 2007 at 08:19:12pm
How can the rack be in the wrong place, the hole the column has to go through isnt that big or can this slight distance out result in it being so wrong? |
21st Apr, 2007 at 08:23:22pm
no no, on the lhs og the rack there is sometimes a centralising hole. You can pot a pin in the hole and thne line everything up knowing that the rack is in the central position.
21st Apr, 2007 at 09:03:12pm
Wil-h is right and that is what has been worrying me. My rack has no hole on the left hand side to centralise it with the locating pin, in fact there is a rubber shroud visible there.
21st Apr, 2007 at 09:06:50pm
Wil, have you had a pint or two tonight, lol Edited by Sprocket on 21st Apr, 2007. On 26th Oct, 2004 TurboDave16v said:
21st Apr, 2007 at 09:16:57pm
21st Apr, 2007 at 09:18:33pm
Bat - can you tell me how can I check it please? If I have to have the rack out I'll go mad!!
21st Apr, 2007 at 10:34:55pm
21st Apr, 2007 at 10:55:33pm
Hm - OK. The rack is brand new and came as an assembled unit and so is the column. The rack took me ages to put in so I'm reluctant to play with it until I'm sure it has a problem. I'd assumed after putting all the effort in it would be simple to centralise and install the column. I wasn't expecting this problem so I can only assume it will be OK once set up properly with correct wheel tracking and alignment.
22nd Apr, 2007 at 08:24:56pm
On 21st of Apr, 2007 at 09:06pm Mini Sprocket said:
Wil, have you had a pint or two tonight, lol I was actually typing in the dark so as not to wake my boy up. My touch typing still needs work!! Fastest 998 mini in the world? 13.05 1/4 mile 106mph
