Home > Help Needed / General Tech Chat > Fuel Starvation
steve1275
Member #: 951
Bromsgrove
Just got the beast fired up,but struggling to get fuel.The pump is in the boot,this is ABOVE the tank,say 25cm,could this be the problem?I also have a glass bodied filter on the suction side and you can see fuel frothing in it.Thanks,
'Where does the engine go?'
Turbo Shed
Member #: 30
Epsom, Surrey
Providing your beast is a turbo.....
have you taken the filter/restrictor out the tank?
glass bodied filter sounds a bit pony. you should use a proper injection filter
the pump should be below the tank but i have used the metro turbo pump in the engine bay of a mini at the top of the inner wing and it worked fine.
below outlet of the tank is where you need the pump*wink*
idealy mounted on the outside on the subframe with some rubber bobbins and a plate securley fasend on
Edited by BENROSS on 10th May, 2007.
just remembered this is a midget is it not?
still the same applies, the metty pumps dont like lifting fuel much due to their design. they prefer a gravity feed to the pump inlet.
I would go further, and say they must have a good clean supply of fuel that is gravity fed.
ie, feed at least 12mm diameter, same as pump.
steve1275
Member #: 951
Bromsgrove
Thanks fellas,as Iain says,this is a Midget,so no subframe.I can make something to get the pump lower tho.The more fundamental reason for the problem however,was the lack of fuel in the tank!Remember,insanity is inherited,you get it from your kids.....
That would cause the air in the system *wink* LOL
Most times when working on something complicated the simple things get overlooked.
steve1275
Member #: 951
Bromsgrove
Thanks Gavin,Your signature animation feels particularly appropriate at the moment!
and efi pumps dont like runnign with no fuel...it burns them out quite quickly....
steve1275
Member #: 951
Bromsgrove
Aother way to do this might be to use a swirl pot in the boot,run the turbo pump feed and return from it,and feed the swirl pot with a Facet pump on the existing tank supply. Any comments?
