| Home > Help Needed / General Tech Chat > overfuelling now | |||||||
12th May, 2007 at 04:21:20pm
anyone got any suggestions on this one? gone from one extreme to another now.
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
12th May, 2007 at 04:43:59pm
has the fuel pressure shot up for some reason?
12th May, 2007 at 05:42:45pm
nope, still at 3.5psi. even tried reconnecting the part throttle lean off pipe. On 20th Oct, 2015 Tom Fenton said:
12th May, 2007 at 05:51:55pm
mine was doing this when the choke wasnt going fullyhome because of the heat sheild.
12th May, 2007 at 05:57:47pm
12th May, 2007 at 06:01:14pm
the mixture screw doesnt appear to help at all, leaned it right off till the jet was right the way up.
12th May, 2007 at 06:48:06pm
If leaning it off at the jet doesn't make a diff then I would check the choke as Ian said. On 7th Nov, 2008 Nic said:
12th May, 2007 at 09:56:48pm
12th May, 2007 at 09:59:38pm
knackered choke assembly
AlexF |
13th May, 2007 at 01:34:41am
is that something that'll just happen overnight though?
13th May, 2007 at 05:50:30am
before you change carb check all the ign side because if you have a week spark that will effect your afr gauge buy showing its rich due to uncomplete burn always looking for them bigger bunches of bannanas |
13th May, 2007 at 09:48:48am
thats the 2nd thing we checked down in newquay after fitting new plugs, swapped my coilpack/leads/plugs/edis for antons and it was still the same. the breakdown chap used his plug tester aswell and it was showing a fat spark on all 4.
13th May, 2007 at 10:45:43am
those pesky choke seals ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
13th May, 2007 at 10:57:24am
they dont come as part of the rebuild kit do they? can't remember changing them when i rebuilt the carb anyway. do burlen do them seperately? On 20th Oct, 2015 Tom Fenton said:
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
13th May, 2007 at 12:56:48pm
yes they do matey
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
13th May, 2007 at 02:07:01pm
13th May, 2007 at 02:12:51pm
never have on mine tbh...i have been thinking about just blocking it off somehow. On 20th Oct, 2015 Tom Fenton said:
13th May, 2007 at 02:19:43pm
i do...
13th May, 2007 at 02:33:06pm
On my 1380 i have the choke set up so when i't pulled it just raises the tick over a bit with out any mixture richening. On 28th Aug, 2011 Kean said:
17th May, 2007 at 01:09:33pm
1050 Posts Member #: 764 Post Whore Staffordshire |
17th May, 2007 at 05:29:38pm
least you know what it is now....
17th May, 2007 at 07:23:22pm
i said choke first, where's me biscuits! lol! |
17th May, 2007 at 08:53:41pm
i know you thought it was the gasket anton, thats why my manifold and exhaust wrap is now covered in WD40...git! On 20th Oct, 2015 Tom Fenton said:
17th May, 2007 at 10:41:53pm
lmfao at bud! My build thread..
