Home > Help Needed / General Tech Chat > hunting at low revs
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Heres an interesting problem for you...
Finally got my new engine for the glittery mini running this afternoon.
It runs fine at fast idle on wards but at idle is hunts really badly.
I think the fault is ignition related as I have sealed up anywhere that air could get in (to the extent of removing all the IC pipes and the turbo control and even the plenum!). The other thing that points to the ign is that it seems to be an exact point in the rev range where it drops into this mode - soon as you are above that number it runs cleanly.
Sadly I don't know the revs as the rev counter is not connect (yet). But I would guess its rough below 1500 rpm.
Alex
AlexF
What igntion system are you running?
I've noticed with my setup if the toothed wheel runs out a little, in certain parts of the rev range it'll only run on 2 cyls!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
arr sorry its on stock metro turbo dissy
the MJ stuff is there just not wired in yet - I want to run it on both for development reasons :)
Alex
AlexF
Could be the module or pick up.
Is it worse when warm?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
its the same hot or cold
module isnt getting hot - I had one that use to muck around and get proper hot.
But I was thinking the same thing... I have a spare dissy I can try tomorrow/next month lol
ALex
AlexF
ALex
No rush then? LOL
Worn dizzy drive, cam chain? Spark scatter?
mattyking
Member #: 873
Thatcham, berkshire
i had a similar problem when i was using a dizzy i thought it was odd as it wouldnt muck about under load. it just wouldnt idle properly changed many things and finally then changed the module with a mate and that was the problem. the module. hope that helps
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Doesn't seem to be any slack in the dissy or its drive - and its the same dissy I've used before on the racer, I know thats not a good enough reason to exclude it from being at fault though.
It won't be the cam chain - its belt drive :)
Now you mention spark scatter I'll double check the dissy cap and ht's in case its cross firing or anything odd like that.
Oh and I will be chaning the module/dissy too
thanks guys
Alex
AlexF
like Tom says it could be spark scatter, it might be worth looking at the bobweight spring's sometimes they develop a bit of slack or get sticky, that can cause this symtom.
