| Home > Help Needed / General Tech Chat > Avonbar Oil Feed Pipe | |||||||
12th May, 2007 at 10:09:09pm
Sorry to drag this chestnut up again, tried a search for pictures i need but i thing they have been removed. What i have is the kit from avonbar, but how do i connect it up to the engine, i can't do it with the pieces i have, am i short of summat or just being thick?
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
12th May, 2007 at 10:11:53pm
Screw anodised fitting into oil pressure gauge hole, tapered end into block, use a touch of PTFE tape. Screw T piece onto this. Then use other anodised fitting to connect oil pipe, and finally fit oil pressure sender using PTFE again. Easy.
12th May, 2007 at 10:27:17pm
Thats the problem Tom, the anodised fitting won't screw into the block, its the wrong thread, if i turn it round it goes in easy but i can't screw the t piece on as its the wrong thread, if you see what i mean. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
12th May, 2007 at 10:27:28pm
Tomk , you are so clever its untrue.lol.
12th May, 2007 at 10:28:04pm
send it back then, |
12th May, 2007 at 10:45:50pm
it looks like i need one of these, same thread at both ends
12th May, 2007 at 10:50:06pm
Give Think Automotive a call they should be able to sort you out with an adaptor. Isambard Kingdom Brunel said:
12th May, 2007 at 10:51:59pm
The thread into the block needs to be a taper type, if the adaptor is wrong send it back as Carl says.
13th May, 2007 at 01:29:44am
i did this for someone a while ago, just incase its any use to you?
13th May, 2007 at 10:48:57am
13th May, 2007 at 03:02:38pm
Gavin, it fits to the oil prsssure sender hole, not the filter pipe banjo. I have oil cooler pipes connected there.
13th May, 2007 at 03:05:58pm
Bud, it looks like i have those three pieces, the T, the fitment for the braid oil pipe in your picture, but the block fitting is exactly the same as the other, i think it shound be the same at each end. will have to give avonbar a ring for a replacement. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
13th May, 2007 at 04:34:22pm
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
13th May, 2007 at 04:40:44pm
chinlesswonder, in your first picture you have the two adapters in the wrong place. the one between the oil feed and the tee-piece in the pic should go into the block, according to buds diagram
13th May, 2007 at 05:14:43pm
BAT, thats a different oil feed. |
13th May, 2007 at 05:43:47pm
Eh bud's diagram is the same as the original pic, i think you have the wrong adaptor. |
13th May, 2007 at 05:51:44pm
13th May, 2007 at 06:52:36pm
My feed pipe is banjo at one end only, going to the turbo. In my picture, the loose fitting on the right, i have two of.Only one end of it will fit into the block, if i screw it in the block, the only thing i can attach to it is the turbo oil pipe. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
13th May, 2007 at 06:59:45pm
13th May, 2007 at 07:17:45pm
hmmm, i shall check. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
13th May, 2007 at 07:50:26pm
Ok, tried the fitment, it goes in the turbo fine but the pipe pouls the manifold, daren't screw it in any tighter.
13th May, 2007 at 07:50:29pm
13th May, 2007 at 07:58:09pm
13th May, 2007 at 08:13:50pm
yeah, there should be 2 different male>male adaptors in the kit, the banjo end is definately for the turbo. On 20th Oct, 2015 Tom Fenton said:
13th May, 2007 at 08:37:21pm
agreed, will ring avonbar tomorrow, thanks for all your help. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
