| Home > General Chat > oil catch tank | |||||||
173 Posts Member #: 873 Advanced Member Thatcham, berkshire |
13th May, 2007 at 10:09:35am
anyone used one or think they are worth using? |
13th May, 2007 at 10:44:08am
Anything to help the engine breath can't hurt m8. Maybe wrong, but I think you have to have a filter on it for road use. On 19th Jan, 2010 wil_h said:
13th May, 2007 at 10:50:55am
Catch tank is a good idea. You really have three choice of what to do with the breathers.
13th May, 2007 at 11:01:27am
ok thanks alot i may get one then sound like a good idea. are the ones of ebay the bling ones any good or is it just the case of a catch tank being a catch tank. |
13th May, 2007 at 11:53:26am
Mine is from Ebay, it's nicely made. but it's heavy, and not big enough.
13th May, 2007 at 11:59:36am
I feel a another fabrication project approaching.......... Edited by Jason G on 13th May, 2007. On 19th Jan, 2010 wil_h said:
13th May, 2007 at 12:06:43pm
were would the best place to fit one be?
My build thread..
13th May, 2007 at 12:19:33pm
cheers will, what do you mean its to small, do they really fill up to quick, was think would a little one off a motor cross bike be big enough as it would save on space. |
13th May, 2007 at 12:41:07pm
On mine, its breather on flywheel housing to rocker cover, then to catch tank On 19th Jan, 2010 wil_h said:
13th May, 2007 at 02:28:56pm
On 13th of May, 2007 at 11:59am butterpoppy said:
I feel a another fabrication project approaching.......... LOL!! On 28th Aug, 2011 Kean said:
13th May, 2007 at 02:58:19pm
mines from the timing chain breather into a T from the rocker cover then to the tank. then mounted on the passenger inner wing. |
13th May, 2007 at 05:36:45pm
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
13th May, 2007 at 05:46:40pm
I feel a another fabrication project approaching.......... do it do it do it
13th May, 2007 at 05:49:58pm
13th May, 2007 at 05:56:02pm
okies people...........
13th May, 2007 at 06:44:16pm
On 13th of May, 2007 at 12:19pm mattyking said:
cheers will, what do you mean its to small, do they really fill up to quick, was think would a little one off a motor cross bike be big enough as it would save on space. Not it doesn't fill up at all, but the regs state 1 litre and it's only 650 ml Fastest 998 mini in the world? 13.05 1/4 mile 106mph
13th May, 2007 at 07:49:49pm
On 13th of May, 2007 at 05:56pm butterpoppy said:
okies people...........let me know what size I/D pipe going to catch tank, size of tank......and do you want filter included. See what I can do.... Alloy welding is my weakest link, so abit of practice needed. Inlet diameter im guessing the same as whatever the standard breather outlets are?? Yeh with a filter would be nice and possibly a drain plug and sight gauge (the two outlets with bit of clear hose between would be a simple solution) Any other thoughts? |
13th May, 2007 at 08:30:07pm
I think im going catch tank route now, after finding my breathers blocked!!
13th May, 2007 at 08:31:56pm
Got some 18mm tube. So can do some to suit and weld outlets on rocker box if required. On 19th Jan, 2010 wil_h said:
13th May, 2007 at 08:32:50pm
13th May, 2007 at 08:48:59pm
Good point matty...I can see your logic there m8 On 19th Jan, 2010 wil_h said:
13th May, 2007 at 09:33:26pm
im just running mine to an old bottle held in a bike-bottle holder on the inner wing ala
14th May, 2007 at 10:28:59am
mine in in the inner wing too. I've also got a seperate tank to catch water too.
14th May, 2007 at 01:30:36pm
mini13
