| Home > Help Needed / General Tech Chat > engine stopping problem | |||||||
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
15th May, 2007 at 12:21:08pm
I have the MJLJ/EDIS setup fitted,When I switch off from idle,the engine continues to run until I press the brake pedal.Anyone seen this?Spurious feed or condenser somewhere? 'Where does the engine go?' |
15th May, 2007 at 02:40:34pm
15th May, 2007 at 04:42:21pm
where did you take your 12v feed from? |
15th May, 2007 at 08:49:42pm
Hi,Thanks Gav,I'll sort one out.Nic I took both the MJLJ and coilpack (relay) from the old coil +ve feed. 'Where does the engine go?' |
15th May, 2007 at 11:17:58pm
Run it it's own dedicated and fused feed!
AlexF |
