| Home > Help Needed / General Tech Chat > Enough room | |||||||
375 Posts Member #: 886 Senior Member London. |
17th May, 2007 at 08:34:13pm
I brought a Modified carburetter spacer with vaccum adapter.
144 Posts Member #: 1677 Advanced Member Netherlands, The Hague |
17th May, 2007 at 09:51:06pm
I dunno, but the first thing I thought -> That one nice aquamist adapter :) |
17th May, 2007 at 10:14:39pm
if thats your carb setup then you need the proper turbo throttle cable plate.
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
17th May, 2007 at 10:15:13pm
you mean it nearly hits the bulkhead without the spacer "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
17th May, 2007 at 10:16:09pm
i was thinking the same thing
Edited by nogin on 17th May, 2007. "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
17th May, 2007 at 10:24:05pm
On 17th of May, 2007 at 10:14pm bud666 said:
if thats your carb setup then you need the proper turbo throttle cable plate. looks lovely though....wonder if i can get mine that clean and nice, hmmm... "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
17th May, 2007 at 10:40:03pm
if thats your carb setup then you need the proper turbo throttle cable plate. were would you get one of them? do they sell them new at somwere like avonbar? sorry to go off topic mate lol cheers josh My build thread..
17th May, 2007 at 10:40:35pm
Yeah the standard one that u get nearly hits the bulkhead. so i was just thinking would the carb fit with the new spacer i have, as it's thicker, just abit worried it wont fit it :( ive got the proper turbo throttle cable plate :), just spraying it at the minute... ill show it once its done.. |
18th May, 2007 at 01:52:03am
you could always use one of the ERA adjustable top steadys and tip the engine forwards a shade with it. I'm just about to sort some stuff out to sell and i have one of them if you want On 20th Oct, 2015 Tom Fenton said:
18th May, 2007 at 05:47:24pm
Have you Got a picture of it bud ? cheers m8.. i brought i new standard steady that goes on the left on the engine, looking from the front. but having probelms getting them bushes in. just waiting to use my mates vice. but yeah, might be interested in that mate, thanks |
18th May, 2007 at 11:54:51pm
needs a lick of paint and new bushes in the one end but other than its good to go.
19th May, 2007 at 09:27:50pm
I can sort you out a new heat shield On 19th Jan, 2010 wil_h said:
20th May, 2007 at 12:26:27am
I have a heat shield. :)
809 Posts Member #: 224 Post Whore Katy TEXAS |
20th May, 2007 at 01:03:01am
I used one of the ERA steadies...
20th May, 2007 at 11:21:55am
Would these Super Pro Polyurethane bushes fit ok in there,, there hard to get in though, even with the vise lol
20th May, 2007 at 11:38:57am
i dont bother with them, they crack and split after a while. i used to stick to std rubber ones which lasted a lot longer then i changed to a solid steady. On 20th Oct, 2015 Tom Fenton said:
21st May, 2007 at 09:06:19am
But from reading on here, them bushes are ment to be good ? |
21st May, 2007 at 09:23:49am
On 20th of May, 2007 at 11:38am bud666 said:
i dont bother with them, they crack and split after a while. i used to stick to std rubber ones which lasted a lot longer then i changed to a solid steady. My experience as well. Rubber forever! No Nic, not that way! On 13th Jul, 2012 Ben H said:
21st May, 2007 at 10:05:29am
Hmm,
21st May, 2007 at 11:20:49am
just look on minispares site for the standard steady bushes, they only cost pence aswell which is a bonus. On 20th Oct, 2015 Tom Fenton said:
21st May, 2007 at 11:21:53am
The poly bushes are good in certain applications, the engine steady is not one of those.
21st May, 2007 at 12:35:14pm
oh right.. so i take it the rubber ones would be alot easy to fit :) ill have to see if someone wants the ones i got from avonbar |
21st May, 2007 at 12:54:43pm
Which ones are they that fit in budds steardy
21st May, 2007 at 03:06:34pm
Which ones do you think?
21st May, 2007 at 04:53:48pm
The top and bottom are the same bush, plus all of them will fit lol. |
