| Home > Help Needed / General Tech Chat > Lack of compression on one cylinder, Think its the cam. | |||||||
21st May, 2007 at 09:04:46pm
I got my turbo engine started today for the first time in about 6 years, It was bought in unknown condition for the basis of a rebuild.
Edited by minimole23 on 8th Jun, 2007. On 7th Oct, 2010 5haneJ said:
21st May, 2007 at 09:06:43pm
Are the cam lobes for that cylinder round instead of spiky? Edited by Tom Fenton on 21st May, 2007.
21st May, 2007 at 09:12:27pm
I will have to check the lift on them, However in desperation I even adjusted the clearences to about 3mm to see if that made a difference due to incorrect grind in the first place. Edited by minimole23 on 21st May, 2007. On 7th Oct, 2010 5haneJ said:
21st May, 2007 at 09:18:30pm
3mm!!! That will make things worse not better.
21st May, 2007 at 09:19:12pm
i would turn the engine over with the rocker cover off and see if all the valve move right.
21st May, 2007 at 09:21:38pm
if you have no feeler gauges, you want a small movement, i.e. just feels like it moves. that would see if the compression is ok anyway but wants adjusting correctly to approx 0.015" or .38mm.
21st May, 2007 at 09:23:47pm
21st May, 2007 at 09:25:26pm
On 21st of May, 2007 at 09:18pm Tom Fenton said:
3mm!!! That will make things worse not better. no I mean -3mm so there was air between the rocker and the valver. I have adjusted it back now anyway. also they were adjusted correctly with feeler guages. On 7th Oct, 2010 5haneJ said:
21st May, 2007 at 09:29:39pm
well if the valves are seating correctly and there isnt a big hole in the piston it has to be rings.
21st May, 2007 at 09:31:48pm
21st May, 2007 at 09:33:38pm
thats exactly why I am so confused, because there is no smoke at all. it isn't under load though, but still i would expect some.
21st May, 2007 at 09:43:02pm
21st May, 2007 at 09:50:45pm
I also thought i'd add there is no smoke out of any of the brethers. something that has just sprung to mind, when i fired it up originally I did so without water and got smoke or steam out the thermostat housing. I gave up trying to figure which of the 2 it was, though there was abosultely no water in it. it had been running for 30 seconds. then i shut it off and filled it with water.
21st May, 2007 at 09:54:49pm
22nd May, 2007 at 01:38:22am
RINGS!............... take the engine out get it bored
22nd May, 2007 at 08:15:51am
I should have expected that comment from Benross!
On 21st of May, 2007 at 09:04pm minimole23 said:
I then got it started and up to normal operating temperature and repeated the test of thumb over the cylinder, still no compression. Tthen bunged loads of oil down the bore and got compression for about 5 strokes of the engine before it was down to pathetic again. I would like to believe its rings but I feel the amount of oil i put down would have concealed any other problem such as leaking gasget faces. Though there was no mayonase in the water. Right off to buy the fitting for the compression tester. Edited by minimole23 on 22nd May, 2007. On 7th Oct, 2010 5haneJ said:
22nd May, 2007 at 08:39:45am
Edited by Bat on 22nd May, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
22nd May, 2007 at 12:47:31pm
22nd May, 2007 at 01:10:44pm
Sounds like cam lobe, had the same problem a few years back. I thought mine was the rings as it had the same symptoms so I went out and bought all the parts I needed for a turbo conversion, as I would be stripping it all down anyway. It was only when I took everything apart I realised the cam lobe was worn (Inlet IIRC).
22nd May, 2007 at 02:02:42pm
yeah i wouldnt say its rings yet. measure the lift on each rocker, its farily easy. infact you would probably notice this just by having the rocker cover off and comparing to the next whilst pushing it along... |
22nd May, 2007 at 03:16:15pm
I will whip the rocker cover off now, I can't push it as the donar car is non existant! On 7th Oct, 2010 5haneJ said:
22nd May, 2007 at 03:29:37pm
socket on the crank pulley nut then |
22nd May, 2007 at 03:29:40pm
22nd May, 2007 at 03:35:22pm
and in comparision to the other cylinders is...
22nd May, 2007 at 03:37:16pm
Sorry I can't count, the lift was 5-6mm the intake was about 0.5mm below the rest on the offending cylinder.
