Home > Help Needed / General Tech Chat > SCCR Gearbox rebuild
nbooth660
Member #: 1234
All was going well... untill I got it made up and the baulk rings are too tight.
I've done some searches and seen some of you guys have had the problem before, but didn't really understand the answer other than putting old rings back in.
I'm using genuine rings at the moment and Richard at Minispares North reckons I may need the competition ones as he's seen the problem before.
Any other ideas?
Nick.
It's true, if you put a full set in it all jams up.
I know people put some old ones back in, as to which ones I don't know....
danboy
Member #: 1381
Did all the gearboxes at the factory jam up when they were first assembled?
What's wrong now that was OK then?
Regards
Dave
I'm guessing here 'cause I know nowt about boxes. I imagine it's to do with the SC gearset as the factory didn't fit them?
danwebster
Member #: 1038
It'll loosen up pretty quickly in the car, 2nd and 4th gear baulks take the worst hammering so if you wanted to leave 1st and 3rd in you probably could, depending on how they looked.
re fit the old ones if they are not totally goosed as i did
2nd gear i had trouble with on the clubman set
this is using the old baulk rings
*surprised*
i got another baulk ring from another box and alls well *happy*
or take richards advice *indifferent*
its the machining on the SC set up which differs, CNC and all that maybe worn tooling
Edited by BENROSS on 25th May, 2007.
turbo hogster
Member #: 178
stowmaket suffolk
common problem is lavk of oil on assembly and the stick to the cones.
use plenty of oil then just gently prize away from the gear cone then they will be ok. unless you have stuck a syncro round the wrong way.
i have never had a problem yet when fitting new baulk rings.
