Home > Help Needed / General Tech Chat > Tight x pin diff
nbooth660
Member #: 1234
Just built up a Minispares x pin diff and it's very tight. Tried different fibre washers on the output shafts and different output shafts and whilst it gets better with different combinations, it still doesn't turn freely.
Anyone experienced a similar problem or know if it will bed in?
Nick.
I had a similar problem with my normal diff with all new parts.
Even after fitting thinner thrusts washers, it was very stiff, like you could hardly turn it by hand, but once on the car it was fine.
Edited by Paul S on 27th May, 2007.
Should also add that when it came to build the x-pin for the 998 turbo, I used a good set of used output shaft thrust washers.
It was still stiff but given the previous experience, I'm happy with it.
johnK
Member #: 690
Norfolk
As above - similar problems with Antmans when it was reconned with new bevel gears etc - used thrusts were the asnwer.
JK
If Carling made Mini engines
nbooth660
Member #: 1234
Was just in the process of trying used thrust washers on the planet gears and it turns freely now.
The new thrusts are visually thinker than the used ones.
Thanks for the confirmation guys.
Nick.
