| Home > Help Needed / General Tech Chat > vacuum for dv | |||||||
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
28th May, 2007 at 06:58:40pm
on the metro/carb there only seems to be 2 places, other than the servo take off for the vacuum for the DV, one of them i know is the part throttle lean off whatsit:) and the other one, if i connect my d/v to it, it doesn't open at all, is there a 1 way valve or something there? its much bigger than the part throttle one..
28th May, 2007 at 07:01:36pm
28th May, 2007 at 07:02:40pm
so for it to work properly i need to drill and tap the manifold?
621 Posts Member #: 393 Post Whore Oulton Park |
28th May, 2007 at 08:45:55pm
buy a spacer plate but having it running off the top of inlet just as good |
28th May, 2007 at 09:43:16pm
28th May, 2007 at 11:51:46pm
where can i buy a spacer from?:)
29th May, 2007 at 12:18:08am
Avonbar, Minispares, Min-Its .... I've seen them from all these companies and they are pretty much all the same. Every day is a school day ...........
