Home > Help Needed / General Tech Chat > Late radiator with fan switch
Turbo Tel
Member #: 588
Delaware, USA
Anyone know at what temp the fan switch activates on this minispares rad?
http://www.minispares.com/Product.aspx?pid=34526
Terry
Edited by Turbo Tel on 2nd Jun, 2007.
82 degrees but you can get 74 degree switches made to order.
Paul
82 is too low, the stat wouldn't be open then.
According to a the catalogue it's 97 on and 92 off, part number SNB 748 fits Nissans and a fair few Rovers.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
As Gavin states if you look through parts catalogues you'll find it's a fairly standard fitment. I am running an 82 deg one from a Nissan with my 1380 as I find that if I let it get to 97 before switching on it can't pull it back and the rad boils over!!! Using a 74deg thermostat as well ..... not sure quite why I have such a cooling issue with the 1380 as I didn't with the previous engine
Turbo Tel
Member #: 588
Delaware, USA
OK
Hmm.. as the stat is at the hot end of the radiator and the fan switch is at the cold end, I guess the stat should be well open by the time the cold end gets to 82 degrees. I believe the water in the engine gets over 100. I think I'm going to get hold of an infrared thermometer and see if I can work out what the temps actually run at...
JT
Member #: 637
Hertfordshire
im sure mine says 97 degrees c.
i only run a leccy fan and it works a treat.
the fan is as big as the rad itself though! lol
it shifts alot of air!!
My build thread..
Turbo Tel
Member #: 588
Delaware, USA
I did get hold of a thermometer, see the other thread..
http://www.turbominis.co.uk/forums/index.p...id=146920&fr=50
