| Home > General Chat > O/T Plumbing | |||||||
2nd Jun, 2007 at 04:31:24pm
Well after the last mini project at home, sorting the gas hob has been completed, my next job is to sort the shower out.....
2nd Jun, 2007 at 05:25:53pm
you need a high level water tank iirc
2nd Jun, 2007 at 06:00:19pm
I have got that, both a hot and cold water tank up in the loft, above the level of the shower head.....
2nd Jun, 2007 at 08:08:28pm
2nd Jun, 2007 at 09:40:24pm
yes, check that your cold isnt from the mains, i.e. when you turn the tap on can you hold the pressure with your finger
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
3rd Jun, 2007 at 09:26:29am
yes a line from the cold tank in the loft and a direct line from the hot water tank would be ideal. This is how my dad plumed his system in not long ago using the same type of pump. I've seen the future and tbh its Pie
3rd Jun, 2007 at 01:05:12pm
I'll have to check where the cold supply comes from.....cheers chaps.....
3rd Jun, 2007 at 08:20:21pm
What is wrong with a bath???? Musch nicer to relax in a nice hot bath IMHO.
3rd Jun, 2007 at 08:52:21pm
Roger, please keep your smutty comments about your "15mm pipe" to yourself |
![]() 6753 Posts Member #: 828 Post Whore uranus |
3rd Jun, 2007 at 08:56:36pm
On 3rd of Jun, 2007 at 08:52pm Nic said:
Roger, please keep your smutty comments about your "15mm pipe" to yourself ![]() ![]()
not to mention your inconsistant temperature and poor flow !!(poor flow is often due to over use or overwork ,il leave it up to you to decide which rog)
![]() 70 Posts Member #: 854 Advanced Member Fareham, Hampshire |
3rd Jun, 2007 at 09:07:52pm
Its up to you but I would not recommend using one of those pumps, pretty sure screw fix sells the same type and to be brutally honest, there shit.
4th Jun, 2007 at 09:56:03am
Thanks for the pointer, however cheap and cheerful is the name of the game currently, I might try a cheap one to see how sucessful it is, with a view to upgrading in the future if it works OK.
4th Jun, 2007 at 10:48:51am
my folks have gone through a couple of pumps as well in a short space of time.
