| Home > Help Needed / General Tech Chat > Slave Cylinders.. | |||||||
2nd Jun, 2007 at 09:42:11pm
Let me get this right
82 Posts Member #: 939 Advanced Member |
2nd Jun, 2007 at 09:50:23pm
Yep. Just swapped to smaller brake cylinders for the exact same reason!
2nd Jun, 2007 at 10:23:49pm
Oops, double post!:$ Edited by bodgeit on 2nd Jun, 2007. |
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
2nd Jun, 2007 at 10:41:17pm
top call here chaps i've had this prob, offto min-its for some cylinders :) maybe new brae shoes too it the mini is a lucky lil thing SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
2nd Jun, 2007 at 10:55:23pm
2nd Jun, 2007 at 11:04:14pm
Smaller Master cyl = more brake
2nd Jun, 2007 at 11:44:39pm
oh fork, now im confused
3rd Jun, 2007 at 05:03:57am
Master cylinder sizes won't help. A bigger / smaller master bore will STILL have the same bias at the rear comapred to the front - you'll just be pushing the pedal harder / less.
3rd Jun, 2007 at 08:06:30am
smaller it is.
Edited by miniminor63 on 3rd Jun, 2007. |
3rd Jun, 2007 at 09:13:28am
urghhh i hate brakes!!!
3rd Jun, 2007 at 09:23:19am
On 3rd of Jun, 2007 at 08:06am miniminor63 said:
smaller it is. If you have a small master cylinder and a big one, the big one should go back as it gives less force, and the small one that gives most force should go to the front. Its just a matter of reversing the formulas used here to calculate the travel or force of the brake lining/cylinder A larger master cylinder moves more fluid therefore gives more braking effect, I fitted 7/8 AP Racing cylinders for this reason as opposed to 3/4 Paul I seriously doubt it! |
3rd Jun, 2007 at 09:30:47am
you do NOT move (much) fluid in a brake system. You transmit pressure. At least as long as there are no compressible fluids in the system. A smaller master cylinder will give higher pressure difference. |
3rd Jun, 2007 at 11:12:13am
On 3rd of Jun, 2007 at 09:30am miniminor63 said:
A smaller master cylinder will give higher pressure difference. No it wont. You have a larger master cylinder to move more fluid then you use a smaller wheel cylinder to create more pressure. You're not trying to tell me that Clive Trickey, Kad and everyone else are wrong are you. I did this on my car which vastly improved the brakes until i fitted rear disks with a bias valve. Paul I seriously doubt it! |
3rd Jun, 2007 at 11:31:27am
Smaller slave cylinders will exert less force for a given fluid pressure than larger ones.
3rd Jun, 2007 at 12:34:39pm
On 3rd of Jun, 2007 at 11:31am Axel said:
Smaller slave cylinders will exert less force for a given fluid pressure than larger ones. Pressure is pounds of force per sqare inch of area. Less area, less force. If you have a certain amount of fluid trsansfer then a small wheel cylinder piston will move further than a large one, putting more pressure on the shoe and drum. Paul I seriously doubt it! |
3rd Jun, 2007 at 01:04:43pm
force = pressure x area.
3rd Jun, 2007 at 01:13:20pm
Paul, It is all about line pressure and not fluid transfer.
3rd Jun, 2007 at 01:57:34pm
Everything Ive ever read, and all the racing specialist Ive ever talked to say put on as larger master cylinder and smaller wheel cylinder. They are the professionals - they know what theyre talking about from theory and practice. Im quoting what they have told me which did work for me.
3rd Jun, 2007 at 02:27:54pm
I dont know, but they are |
3rd Jun, 2007 at 04:27:03pm
It is intuative to think a large master cylinder will give more pressure but it is wrong. A basic knowledge of Hydaulics will tell you that it is wrong.
