| Home > Help Needed / General Tech Chat > Fueling | |||||||
39 Posts Member #: 1195 Member Fort Worth, TX USA |
2nd Jun, 2007 at 10:03:15pm
So got my mini over to the dyno for the first time since i swapped in the Metro Turbo engine to get the boost and fueling sorted out. Seems like I am having fueling problems where I am way overfueling at low boost and becoming dangerously lean at high boost (see chart). The tuner is not overly familiar with my particular carb (HIF44). Any sugestions on what i can do to tweak it to where i reverse the AF curve? Be kind, this is my first carburated car, so it's a learning experience. Thanks for the help
2nd Jun, 2007 at 10:03:52pm
Forgot the chart
2nd Jun, 2007 at 10:44:18pm
Edited by Bat on 2nd Jun, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
4th Jun, 2007 at 09:06:26pm
checked the pressure and it was on the high sde (5.5psi). Adjusted it down to 3.5 and will continue checking items down the list. Thanks |
4th Jun, 2007 at 11:17:30pm
