Home > Technical Chat > megajolt not communicating
philc
Member #: 1346
bromsgrove
This is not yet connected to my car, i am just going through the instrustion on how to get to know my megajolt. I have done a search though their is similar issues, i am still not sure. I have gone through the process and my screen which is the configurator V3.2.1 - no file loaded has no numbers and still says could not open port. i have bought a serial - usb cable. I have gone into device manager/serial ports which states prolific usb-serial com port (Com9). still says could not open port. Any suggestions gratefully recieved. thanks
What com port is the MJ software set to?
philc
Member #: 1346
bromsgrove
com port you mean which usb port, or do you mean 9600 changed to 4800 which i have done. i have just downloaded version 3.1.1 still no change
Your usb to serial is set to com9, so the MJ software needs to be set to com9 also.
It's probably set to com1 or 2 out of the box *wink*
I'm sure you need to use the same version of sofware as firmware in the MJ.
Edited by Bat on 2nd Jun, 2007.
In configurator V3.2.1 select tools then configuration options and try a few different values for the com port, mine changes depending which USB port I plug my adaptor into.
themaninthesuitcase
Member #: 1124
Surrey
If you go to the device manager you can see what port it's chosen to assign it's self too. I created a short cut to the device manager on the desktop to make this easier (I can't remember how but I googled "device manager shortcut")
philc
Member #: 1346
bromsgrove
spot on dude, i have changed the com port by loading up the version 3.2.1 going into tools/confirguration options then changing the com port. Then clicked on get ignition and now have lots of numbers. cheers guys top banana *happy*
No problem phil *wink*
philc
Member #: 1346
bromsgrove
Gav have you got one set all uo then??
No I run an Omex, never even seen a MJ!
Second problem I've sorted for someone on here though *wink*
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Yeah your a legend!
On 7th Nov, 2008 Nic said:
naeJ
m
Aw, thanks! :$
*wink*
