| Home > Help Needed / General Tech Chat > Best way to remove a stuck crank pulley bolt? | |||||||
3rd Jun, 2007 at 07:47:34pm
Having just bent a half inch ish bar in half trying to undo the pulley bolt I am a bit stuck as to where to go next.
Edited by minimole23 on 3rd Jun, 2007. On 7th Oct, 2010 5haneJ said:
3rd Jun, 2007 at 07:51:08pm
You have bent the locktab back right?
3rd Jun, 2007 at 07:57:35pm
if the engine is out, take it down to your local tyre place, ask em nicely to remove it with the windy gun, would help if you took the right size socket for them to use. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
3rd Jun, 2007 at 07:58:23pm
if all else fails then bluntish cold chisel and a lump hammer im afraid but that should shift it. always looking for them bigger bunches of bannanas |
3rd Jun, 2007 at 08:20:37pm
3rd Jun, 2007 at 08:49:02pm
i hate to admit this ,but i have heard of certain peeps putting the breaker bar against the ground and cranking the engine to shock it loose !! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
3rd Jun, 2007 at 08:52:18pm
if its in the car, a breaker bar with a scaffold pole on the end will def shift it, as long as the flywheel is locked through the starter motor. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
3rd Jun, 2007 at 09:01:48pm
3rd Jun, 2007 at 10:36:44pm
What is it with brummies and hammers???
3rd Jun, 2007 at 11:45:58pm
4th Jun, 2007 at 07:03:38am
lol Every day is a school day ...........
4th Jun, 2007 at 02:17:31pm
Lol..Ive not heard that expression for ages...it is true then. Lol
4th Jun, 2007 at 02:55:36pm
I have now tried heat and a tickle with a chisel. I will ring someone I know to see if I can borrow one of his compressors and a windy gun.
4th Jun, 2007 at 03:04:37pm
4th Jun, 2007 at 05:08:36pm
windy gun is the best bet for sure. love it!
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
4th Jun, 2007 at 05:28:45pm
i'm only a very lil chap & i use a 10ft scaff pole, works a treat, i've just got a bigger compressor & a cheapo windy gun & sand-blasting from Aldi! so i think it'll be worth the investment, windy-gu shock tactics seem to do the trick most times!
