Home > Help Needed / General Tech Chat > Hard to get in gear
Zeemax Power
Member #: 393
Oulton Park
Tryed car to day first i could only get revise then with lot of push and pulling found all the gears, but it seems hard and before that i thought i had selected a gear, but could hear a spining noise like had not quiet gone in and wasnt engaging. Its really weird is it anything to do with the cluch not working. It seems easy to push! i thought that was down to springs. Does is cleanace any different cos i followed the 6.5mm out the book. thanx
http://www.Zeemax.com
I tried the car today, at first I could only select reverse, then with alot of pushing and pulling I could select all of the gears, although it seems hard.
Before this it felt like I was selecting a gear, but could hear a 'spinning' noise as if it wasnt fully engaged.
Its really wierd, is it anything to do with the clutch not working?
It seems easy depress the clutch pedal!
I thought that was down to springs (the diaphram?).
Does clearance make any difference, because I followed the 6.5mm as it states in the book.
Thanks
If the pedal is easy to press it could well be a hydraulics problem.
Knackered master or slave cylinder?
Just needs more bleeding?
Sounds like too "little" clutch to me..
Zeemax Power
Member #: 393
Oulton Park
had enough go today not all that bad as i first thought bit silly really never hard straight cut drops on the side and diddnt reaise how noisey they are i think its that
turbo hogster
Member #: 178
stowmaket suffolk
also check to make sure the adjuster for the clutch arm is to big you want about 10 thou here max.
