Home > Help Needed / General Tech Chat > quicky, i think? threadlock! which type
clubminiflip
Member #: 54
nr coventry
i have 2 types of threadlock here that i'll put my galley plugs in with i have red goo in a tube made by locktight & a blue stick of thead locking compound! (looks like lipbalm)
is there a best type for the job! as it has to seal the joint oil-tight aswell does'nt it
cheers all
Red is usually classed as permanent ie bastard to undo if you need to. Blue semi permanent, easier to undo when you want too. I'd go for the blue.
LukeAnsley
Member #: 193
If the Red Loctite is 542 Loctite that is a hydralic sealant so i would say that would be better for sealaing the threads on gallery bungs. The Blue is usually just a thread locker to stop it from coming undone, not actually sealing it.
Luke
danboy
Member #: 1381
Warming Locktite up to 300-350 Degrees C will break the bond and allow easy removal
Regards
dave
clubminiflip
Member #: 54
nr coventry
well i hope the galley plugs wont have to come out for a good while so.......... i'm having thoughts to use the red 542 being the hydrolic sealent, oil pressure is all in these areas aint it!
