Home > Help Needed / General Tech Chat > Metro Clutch arm?
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Is this a metro clutch arm? I presume its verto. I went to fit a new pushrod but realised the clutch arm was completely different to what it should be lol
Also just wanted to check if this is the right slave cylinder too*oh well*
Edit: Just realised it is a verto slave!
Still no idea about the arm though!
Rich
Edited by richminiturbo. on 9th Jun, 2007.
It's a metro arm, they are considerably longer than the Mini arms as the metro uses a cable to operate the clutch.
the eary metro did not use a cable set up if iam right ?
place an add in the wanted section
The early Metro was hydraulic. Was there a pre-verto Metro?
EDIT: I don't think there was, it just had the old type starter motor on it.
Edited by Bat on 12th Jun, 2007.
