| Home > Help Needed / General Tech Chat > I think my brand new adjustable rear radius arm brackets are manufactured to the wrong size. | |||||||
14th Jun, 2007 at 08:51:40pm
I recently bought some minispares adjustable rear radius arm brackets.
14th Jun, 2007 at 08:57:40pm
Dont the brackets bolt on the outside, so the plate that we can see would be ontop of the subby! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Jun, 2007 at 09:05:45pm
Oh the standard one fitted perfectly.
14th Jun, 2007 at 09:11:46pm
I wouldn't use a file, just in case you want to send them back m8 On 19th Jan, 2010 wil_h said:
197 Posts Member #: 1488 Advanced Member Bristol |
14th Jun, 2007 at 09:30:44pm
Quite intrigued by this as I'm gonna be looking at getting my suspension sorted soon...
Edited by Badger on 14th Jun, 2007. There is no sense crying over every mistake- you just keep on trying til you run out of cake. |
14th Jun, 2007 at 10:16:29pm
Looks about normal for the MS brackets.
14th Jun, 2007 at 10:35:25pm
looks just normal, I did as will suggest and it worked. |
15th Jun, 2007 at 02:20:37pm
Yep standard, just wait till you try and set the front to back alignment. Had to cut and 1/8th of an inch off of the o/s bracket on both Axel's, Josh's, my mate Stuart's and the Mighty Mini I set up! MS quality! On 5th Sep, 2011 Vegard said:
15th Jun, 2007 at 08:16:31pm
Makes you realise its worth paying the extra for the likes of the KAD ones if it saves a lot of time. |
16th Jun, 2007 at 08:15:06am
I bought the minispares ones assuming that they would actually fit. I'm going to complain - It may appear that I am really pissed off about this but i'm not. Just can't undersand how difficult it is to produce a simple bracket. On 7th Oct, 2010 5haneJ said:
16th Jun, 2007 at 08:25:22am
16th Jun, 2007 at 08:42:21am
16th Jun, 2007 at 01:09:09pm
Looking at the MS website the ones they have are different from the ones I bought from them about 5 years ago. Those ones fitted fine, only needing the holes slotted if you were using shims to adjust toe. On 7th Nov, 2008 Nic said:
16th Jun, 2007 at 04:33:09pm
On 15th of Jun, 2007 at 08:16pm iain said:
Makes you realise its worth paying the extra for the likes of the KAD ones if it saves a lot of time. The KAD ones fit perfectly but they are a bitch to set the rear toe & camber as there is no threaded adjuster like the MS ones. I discussed this with Colin & Dave @ KAD and there was a lot of shrugging! So to make the KAD one perfect this is what they need. On 5th Sep, 2011 Vegard said:
17th Jun, 2007 at 12:52:05pm
The last half dozen or so sets of brackets I've fitted to my cars and others have fitted spot on ...... not supprising when you consider I bought them from Min-Its!!!!!
17th Jun, 2007 at 04:08:26pm
Pics & prices of Min-Its ones please?
On 17th of Jun, 2007 at 12:52pm RogerM said:
The last half dozen or so sets of brackets I've fitted to my cars and others have fitted spot on ...... not supprising when you consider I bought them from Min-Its!!!!! For parts like this it's a total no brainer or me .... the Min-Its stuff just works ... if you do have any problems with their stuff a quick call will soon have it all explained without once stating what a pratt you've been .... although Dave is no doubt thinking it!!! LOL Get what you pay for. On 5th Sep, 2011 Vegard said:
17th Jun, 2007 at 06:07:49pm
I have some in the garage, camber only .. toe via shims ... they are my preference to the knurled plate type ones.
17th Jun, 2007 at 08:51:36pm
On 17th of Jun, 2007 at 06:07pm RogerM said:
I have some in the garage, camber only .. toe via shims ... they are my preference to the knurled plate type ones. Will post pics next time I'm in there (but that could be a while as I find it really depressing to go in there and see the Mini knowing that it will be weeks, maybe months, before I can even think of picking up a grinder again :( ) I know the type - shims = PITA - had hoped there was a third type I did not know about! On 5th Sep, 2011 Vegard said:
18th Jun, 2007 at 10:47:01pm
Fairy snuff then Scruffy. I personally think the knurled type are a PITA as I have never known a set stay put!!
18th Jun, 2007 at 10:55:02pm
18th Jun, 2007 at 11:29:36pm
Jason ....... LOL ... something else for me to design and you to make I think .... if I ever get around to doing my bit ...... Every day is a school day ...........
19th Jun, 2007 at 01:51:18pm
Interestingly enough I have just last night done the rear tracking and toe. I have the KAD brackets.
19th Jun, 2007 at 02:12:07pm
We have a 4 hour racer here in Norway that have given up on all these type of brackets as the all moved a lot during a race. He has now made his own setup with camber adjustment on the outside and toe on the inside. He has the bolt system also used on the minispares brackets to hold things in situ if I remember correctly. Another possibility is to weld them when you are pleased with the setup you have... |
19th Jun, 2007 at 08:08:14pm
On 19th of Jun, 2007 at 02:12pm miniminor63 said:
We have a 4 hour racer here in Norway that have given up on all these type of brackets as the all moved a lot during a race. He has now made his own setup with camber adjustment on the outside and toe on the inside. He has the bolt system also used on the minispares brackets to hold things in situ if I remember correctly. Another possibility is to weld them when you are pleased with the setup you have... The best way - my beam adjusts at either end of the arms too.. On 5th Sep, 2011 Vegard said:
