| Home > Help Needed / General Tech Chat > not runnin right | |||||||
![]() 9 Posts Member #: 1777 Junior Member Glasgow |
15th Jun, 2007 at 06:23:01pm
alright folks, just found your site after bein told about it by a friend. im currently installin a turbo engine into my midas kit car and havin difficuties gettin it to run right, the spec is,
plastic-fanny-tastic |
15th Jun, 2007 at 06:31:17pm
Oil in dashpot?
15th Jun, 2007 at 06:35:13pm
i forgot when at first after gettin the oil pressure up and ive tried 3in1 and 10/40w both the same results, cheers plastic-fanny-tastic |
15th Jun, 2007 at 06:40:08pm
double check the pipes on the side of the carb are blocked off properly, had this trouble when i first installed mine cos i hadn;t blanked off the anti run on pipe properly. On 20th Oct, 2015 Tom Fenton said:
15th Jun, 2007 at 07:06:11pm
had it blanked off to begin with, but acctually ran better with it open, ( that is the pipe next to the fuel intaked?) plastic-fanny-tastic |
15th Jun, 2007 at 07:13:57pm
15th Jun, 2007 at 07:24:31pm
cheers man,
15th Jun, 2007 at 08:24:33pm
yep that will fix it i reckon, two of my turbo engines had the same symptoms and were cured by that link! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
16th Jun, 2007 at 01:54:36pm
Check inlet manifold & carb gaskets for air getting in. On 19th Jan, 2010 wil_h said:
